Ad Details
ExcellentPayment Method
CashRegion/State
(VIC) Victoria/AustraliaSuburb or Town
VermontOriginal Receipt Available
NoShipping & Pickup Options
Shipping: Not availablePickup: Available
Auditioning
NoReason for Selling
No longer requiredFurther Information
Mission Electronics Model 700 Leading Edge bookshelf speakers. Made in England. Excellent sound and condition for their age, slight imperfection on one of the corners per photo.
Hifi Engine brief:
Advanced technology has been used to develop an exceptional 7 inch bass-mid drive unit. Shaped pole pieces and an ultra-fine voice-coil gap combine with a rigid high mass cone, to produce an unusually extended bass response. Refined cone geometry and damping, with progressive hyperbolic suspension affords both high power handling, and inherently low colouration.
This bass-mid unit is complemented by a ferrofluid cooled 19mm dome tweeter. The system is capable of handling musical material with exceptional dynamic range, including digital masters, and remains linear even at modest power levels - unlike many non-linear systems which, at low level, sound little better than a transistor radio.
The unusual inverted drive unit geometry, first designed by Henry Azima in the Mission 700, goes some way towards equalising the distance from the acoustic centres of the drive units to the ears of the normally seated listener. The effect of such a design is that at the crossover frequency the radiation lobe is directed up towards the listener rather than down to the floor.
The refinement goes one step further in the use of a time delayed baffle board resulting in dramatically better acoustic phase linearity, with substantial improvements in realism, dynamics, and stereo imagery. The baffle board itself is precision injection moulded in polypropylene reinforced with natural composite materials. This combines with Mission's multi-fold technique for cabinet construction to ensure phenomenal transient attack.
Specifications:
Type: 2 way, 2 driver loudspeaker system
Frequency Response: 55Hz to 20kHz
Recommended Amplifier: 20 to 75W
Crossover Frequency: 3500Hz
Impedance: 6Ω
Sensitivity: 90dB
Bass: 1 x 177mm plastiflexed cone
Tweeter: 1 x 19mm polymer dome
Finish: Walnut
Dimensions: 210 x 205 x 380mm
Weight: 12kg
Year: 1985
There have been no submitted ads yet.
