Ad Details
Price
AUD $2,500RRP/MSRP
AUD $5,300Product Type
Linear Power SupplyBrand
NordostModel Name
QsourceCondition
ExcellentPayment Method
Paypal, EFT, Cash on PickupRegion/State
(VIC) Victoria/AustraliaSuburb or Town
ReservoirOriginal Receipt Available
NoShipping & Pickup Options
Auditioning
NoReason for Selling
NLRFurther Information
For sale is simply one of the best World Class Linear Power supplies available and rare to find one on used market.
Comes with Two Nordost Qsource premium 1.5m long Dc Cables.
One is Lemo to 2.1mm , the other one Lemo to 2.5mm. RRP on the dc cable itself is $650 ea.
No longer required so grab a bargain.
Nordost Qsource power supply is ideal for the streaming rig like Roon Nucleus IMO and will supercharge your digital front end to a component level upgrade. It has Six outputs in total . Four of them are designed at 5v to use with Nordost Qpoint Synchronizer mainly . However I find it ok to use 5v output at low wattage comsumption device like Jcat XE usb card (5v /1A) for example.
The other two outputs (A and B ports) provide viariable voltage outputs from 9v to 24v(image attached)
Both Qsource and Qsource dc cables comes with Complete packaging.
SPECIFICATIONS
AC Power Input: Switchable 110/220 VAC 50/60 Hz
AC Fuse: 1.25A Time-Lag, Ceramic Body
DC power output:
For each variable output @ 19/24 VDC: 66 W
For each variable output @ 12 VDC: 20 W
For each variable output @ 9 VDC: 10 W
For all 5V outputs combined: 5 W (5V Mainly designed to use with Qpoint Synchronizer)
PSRR: 75 dB
Dimensions: 280 x 121 x 67mm (11in x 4.75in x 2.625in) w/ feet
Weight: 2.7kg (6lb)
