Ad Details
Price
AUD $420RRP/MSRP
AUD $565Product Type
Linear Power SupplyBrand
PD CreativeModel Name
LPS30 SECondition
As New / MintPayment Method
Paypal (Buyer pays any fees), COD, Bank TransferRegion/State
(SA) South Australia/AustraliaSuburb or Town
FullartonOriginal Receipt Available
YesShipping & Pickup Options
Auditioning
NoReason for Selling
SpareFurther Information
PD Creative (Poland) Super Low Noise Special Edition Linear power supply upgrade kit for Lumin D2, D3, U1/U2 Mini
Comes with all original accessories and packaging including PSU adaptor. Ordered recently but didn't get much use due to change in direction. In brand new condition, open-box.
Clarity, midrange and bass improved noticeably to me with addition of LPS.
Please feel free to message me with any queries.
Description from the website:
LUMIN D2, D3, U1/U2 MINI – SUPER LOW-NOISE ‘SE’ PSU UPGRADE KIT
Special edition of our super-low noise power supply with power adapter, dedicated to Lumin D2, D3, U1/U2 Mini players.
Built with high-quality discrete components, it provides clean, interference-free power for your devices. Made in a black steel housing with an integrated IEC socket with a switch and a fuse.
PSU specification:
special housing construction isolating the AC transformer from the electronics and the regulator
dedicated 70VA toroidal transformer with increased amount of copper and improved shielding
Mundorf M-Lytic AG and Panasonic FM capacitors, with a total capacity exceeding 35000uF
gold plated PCB finish
AC and DC sockets with high quality contacts (gold plating finish)
internal wiring made from OFC copper
two stage voltage regulation with a soft start procedure, and additional ripple filter
high PSSR, low noise floor: -148dB to -176dB in the range from 100Hz to 100kHz
low noise level: <4 uV AC RMS for the 0-20kHz frequency band (6 uV in the 0 to 100kHz range)
low Peak-Peak voltage: <50uV
maximum allowable current 2.5A
set includes an OFC 4N IEC cable (3 x 0.75mm) and a DC cable on the GX16 connector.
output voltage: 12V
dimensions: 120 mm width, 53 mm height, and 215 mm depth
weight: 1.8 kg
PSU adapter:
replaces the factory SMPSU power supply with a AC socket
made of uniform material of high quality and dimensional accuracy
Schurter DC socket – 5.5/2.1mm type
original JST connectors (Mfg by Japan Solderless Terminal), machine crimped with cables (made as twisted pair)
high-quality TX10® precision screwdriver included in this set
The power supply is characterized by a constant noise level up to 2.5A load. Each power supply is tested before shipment and has individual ripple and noise measurement results attached to it (measurements were made with a current load of 1A)
View All Ads Combine & Save - Other Ads from Gotham
