Ad Details
Price
AUD $2,500RRP/MSRP
AUD $5,295Product Type
Power ConditionerBrand
PS AudioModel Name
P3 Stellar Power PlantCondition
As New / MintPayment Method
CashRegion/State
(VIC) Victoria/AustraliaSuburb or Town
MelbourneOriginal Receipt Available
NoShipping & Pickup Options
Shipping: Not availablePickup: Available
Auditioning
NoReason for Selling
No longer requiredFurther Information
Power Plants are regarded for their ability to reduce noise and THD to virtually zero while providing rock steady voltage output. Traditional power conditioners can only affect a portion of incoming noise and are unable to compensate for over or under voltage. Furthermore, power conditioners raise the impedance of the power going to your system, which can bleach your sound and drain away dynamics. The P3 handles things completely differently. Through the P3’s active regeneration process, it is able to provide perfect power while also lowering the impedance, increasing the dynamics and openness of your system.
Best of all, the P3 features overbuilt surge and spike protection, meaning you can rest easy knowing your system is safe.
Don’t starve your music or risk damaging your equipment. A P3 gives you greatly improved performance and safety from just plugging into the wall socket and far better dynamics, more authoritative bass and a much bigger, more open soundstage than any passive power conditioner on the market. Why settle for anything but a Power Plant? Take one home and try it today.
Specifications
Environment Specification
Europe/Asia
Location Indoor use only
Duty Cycle Suitable for continuous operation
Moisture Sensitivity Not sealed against moisture
Operating Humidity <80%rh
Storage Temperature -40C to +40C
Operating Temperature 0C to 40C
Electrical Supply Nominal Rating 230V 10A 50/60Hz
Instrument Specification
Europe/Asia
Unit Dimensions 17” W x 12” D x 3.25” H (43cm x 30.48cm x 8.255 cm)
Unit Weight 31.4 lbs ( 14.24 kg)
Shipping Dimensions 17” W x 12” D x 3.25” H (43cm x 30.48cm x 8.255 cm)
Shipping Weight 39.4 lbs (17.87 kg)
Nominal Input Voltage 200 –270 VAC
Maximum Continuous Load 300VA
Maximum Peak Load (30 seconds) 1000VA
Voltage Regulation <0.2%
Typical Output THD <0.3%
Output Impedance <0.008 ohm
Efficiency @ 300VA >85%
Input Frequency 45 – 65 Hz
Energy Dissipation 850J
Peak Current Surge 60,000A
Max Surge Voltage 6,000V
Clamp Level 800V
DC Trigger None
View All Ads Combine & Save - Other Ads from Rocket66
For Sale
Audiovector R3 Signature Floorstanding Loudspeakers
By Rocket66
2 days and 2 hours
- 225
- 0
- 2
- 0
AUD $7,500
For Sale
For Sale
For Sale
Harbeth P3 ESR XD (BLACK) Bookshelf Loudspeakers
By barbz127
6 days and 18 hours
- 61
- 0
- 3
- 0
AUD $2,800 -
For Sale
For Sale
