EXPIRED Deal 15% off Waversa WLAN Noise Isolators $1695.75 @ Audio Connection
Normal Price: AUD $1,995.00 - Deal / Special Price: AUD $1,695.75
  • 0 replies
  • 5 hits
  • 949 views
  • Dates
    Submission Date:
1 Image
Ad Details
Normal Price
AUD $1,995.00
AUD $1,695.75
Start Date
Expiry
Further Information
This deal from Audio Connection is exclusive to StereoNET members. 15% off and Free Shipping with coupon code above.
Quote
The Waversa Systems Noise Isolator series is a new technology that isolates the noise that is inevitably generated during digital transmission, rather than simply isolating the electrical signal of digital signal noise.
The WLAN Isolator range employs a patented technology that uses electromagnetic waves to eliminate noise. This device is designed to remove noise generated from the LAN port and external sources, enhancing the clarity of musical nuances. While the name "isolator" might suggest a simple function of noise isolation, the technology behind it is quite complex. The primary role of the WLANIsolator is to block EMI noise that infiltrates the cable. Although RFI noise that breaches the cable's shielding is typically managed by the cable itself, complete blockage is often unattainable regardless of the shielding quality.
The Reference and Reference Plus are designed for serious high-end audio users, and are equipped with vibration and further improved noise reduction technology in a machined aluminum housing.
One of the most impressive noise reduction systems we've seen in the world. Simply sit these noise reducers in line with the ethernet connection to your streamer, and you will not only hear a huge improvement, but interacting with the streamer will be faster.
WLAN_EXT2_Resize.jpg?v=1720591077&width=
View All Ads Combine & Save - Other Ads from StereoNET
