Ad Details
Price
AUD $4,490RRP/MSRP
AUD $6,799Product Type
Subwoofer (Active / Powered)Brand
SVS SoundModel Name
PB16 UltraCondition
ExcellentPayment Method
Paypal, direct transfer, Afterpay, credit card in store, cashRegion/State
(WA) Western Australia/AustraliaSuburb or Town
MidlandOriginal Receipt Available
YesShipping & Pickup Options
Auditioning
YesReason for Selling
Trade inFurther Information
4 years warranty left
Subwoofer Specs:
Black Oak and Piano Gloss Black finish options
Protective non-resonant steel mesh grille
Front-firing 16" driver
Rear-mounted amplifier
Screw-in rubber feet
Triple 3.5-inch ports
Robust Medium Density Fiberboard(MDF) cabinet construction
Cabinet Dimensions: 25" (H) x 21.7" (W) x 28.3" (D) (without grille)
Cabinet Dimensions (with grille): 25” (H) X 21.7” (W) X 30.9” (D)
Shipped Dimensions: 34.2" H X 27.5" W X 38.6" D
Weight (unboxed): 174.5 lbs
Shipped Weight: 207.3 lbs
Driver Specs:
SVS 16” Ultra-series driver
Powder-coated cast aluminum basket
Four high-grade ferrite magnets
Finite Element Analysis (FEA)-optimized motor structure
Dual shorting rings reduce gap induction and lower distortion
Extended pole piece improves heat sink and thermal management properties
8” diameter, high-power edge wound voice coil
95mm peak to peak Xmech excursion (82mm Xmax)
Upgraded Nomex spider for improved linearity and driver control at extreme drive levels
Dual 24-strand copper and Nomex composite high-temperature leads provide a pristine electrical connection from the amplifier to the voice coil
Premium glass fiber laminated dustcap and reinforced composite cone sub-structure ensure a light, ridged, and neutral radiating surface
Low-creep rubber long-throw surround for excellent durability and longevity
Amplifier Specs:
Sledge STA-1500D DSP amplifier
1,500 watts RMS continuous (5,000+ watts peak dynamic)
Efficient and cool-running Class D topology
High resolution 50MHz Analog Devices Audio DSP with double precision 56bit filtering is most advanced subwoofer processor available for perfect audio reproduction
Active PFC (Power Factor Correction) ensures the cleanest 1500W output regardless of your home mains supply
XLR and RCA stereo input/output with ultra-wide input voltage for consumer and professional audio applications
Convenient front-mounted display with subwoofer controls and 8 digit LED display
Groundbreaking Subwoofer Control and Bass Management Smartphone App for Apple and Android Devices
IR Remote Control
Three user adjustable parametric EQs
Continuously variable volume/gain control
Continuously variable (0-180 degrees) phase control
Continuously variable (30-200 Hz) 6, 12, 18, or 24 dB/octave low pass filter frequency with disable/LFE setting
Main power rocker switch
Auto-On / On / Trigger Controls
3-12V trigger with 1/8” (3.5 mm) TRS mini-jack input
Green standby mode with > 0.5 watts consumption
Input impedance 22kohm (RCA)/ 22kohm (XLR).
RoHS compliant, lead-free construction and world-wide safety certifications
Detachable power cord
