SMX5000 Posted April 30, 2016 Posted April 30, 2016 Item: Tannoy System 15 DMT mk2 Location: FrankstonPrice: $3,500Item Condition: Good condition, some minor cosmetic marks and wear in places on cabinetReason for selling: Not been used for a while - time to thin the collectionPayment Method: Pickup - Cash, Paypal, COD OnlyExtra Info: Pickup preferred, although happy for you to arrange shipping at your risk. They are very heavy and don't have boxes. Pair of very high quality studio monitors, featuring 15" dual concentric point source drivers. Mechanically and electrically in very good condition however there are some minor marks to the cabinets with the finish worn in places. Frequency response (1) 38 Hz – 25 kHz Recommended amplifier power 50 to 400 w rms into 8 Ω Power handling Average: (2) 200 wrms Programme: 400 wrms Nominal Impedance 8 Ω Sensitivity (3) 101 dB SPL /2.83V @ 1 m Distortion < 0.5% Dispersion (@ -6dB) 90 conical Crossover frequency 1.1 kHz CABINET Drive units 15" full range, single Point Source, Dual ConcentricTM Low frequency design Optimised bass-reflex loaded, in 140 litres Cabinet construction MDF (36mm - front and back; 20.6mm - top, bottom and sides) with energy absorbing bracing matrix and TF-2 acoustic wadding Cabinet finish Velti shadow grey soft-texture finish. High pressure twin laminate in shadow grey with metallic speckled finish on top, bottom and sides Cabinet dimensions (HxWxD) 840 mm x 550 mm x 440 mm (33†x 21.6†x 17.3â€) Cabinet weight 45kg (99.2lbs) Pictures:
