Benny G Posted September 1, 2018 Posted September 1, 2018 @Spider27 JLS recapped and serviced my nad c300 amp for $160. Turn around iirc was about a week. They are great to deal with. 1
Spider27 Posted September 1, 2018 Posted September 1, 2018 On 01/09/2018 at 12:27 AM, Benny G said: @Spider27 JLS recapped and serviced my nad c300 amp for $160. Turn around iirc was about a week. They are great to deal with. Expand Thank you. Great to know. I will definitely check them out
Willmax Posted September 2, 2018 Posted September 2, 2018 Adept were very Inept when it came to a Yamaha B1 amp I had, no clue whatsoever, even though they are supposed to be Yamaha Authorised repairer. They might be ok with other amps/repairs but I have no experience of my own.
Sub Sonic Posted September 2, 2018 Posted September 2, 2018 (edited) Unfortunately Inept also ruined a custom amplifier I had... by simply neglecting to place heatsink paste between a transistor and mica washer. The resulting problem took out a number of other components in the amp and also smoked a coaxial speaker driver. Edited September 2, 2018 by Sub Sonic
DrTobiasFunke Posted September 3, 2018 Posted September 3, 2018 So does that mean there is no-one recommended in Adelaide? Bummer... And sorry if I'm not following.... but who is Bruno? Thanks!
darthlaker Posted September 3, 2018 Posted September 3, 2018 On 03/09/2018 at 10:31 AM, DrTobiasFunke said: So does that mean there is no-one recommended in Adelaide? Bummer... And sorry if I'm not following.... but who is Bruno? Thanks! Expand @DrTobiasFunke Bruno is the man. 100% @Cello Sweet. brunzk@bigpond.com Bruno has been around audio for decades. He makes his own stuff. He repairs anything hi-fi related. He sets up turntables. He is an SNA member (Cello Sweet.) His email is listed above. He knows his stuff. I have entrusted him with my gear - he is meticulous. 100% guaranteed you will be impressed. 3
DrTobiasFunke Posted September 3, 2018 Posted September 3, 2018 Thanks for the response Darth.... I look forward to experiencing Bruno's magic:) 1 1
mattjtaylor2809 Posted September 4, 2018 Posted September 4, 2018 I can 2nd Bruno, he’s performed a few repairs for me & he’s very good 1
Solanum Posted September 8, 2018 Posted September 8, 2018 I had some work done on a Linn amp, went through Jim Tate. They didn't do it themselves, but had someone they work with to do that here in Adelaide. No idea whether it was this Bruno chap, but you could give them a ring and see if you can get the name off them?
Audiofix Posted September 25, 2018 Posted September 25, 2018 On 10/08/2018 at 1:14 AM, dammers31 said: I keep watching this thread.. I need to get a Sansui AU-419 recapped - well I think I do, it has gone into Protection Mode. I had hoped in Melbourne. Any recommendations? Expand I would have thought more likely a small signal transistor but yes caps do play up in them. Many Melb recommendations in this thread.
Audiofix Posted September 25, 2018 Posted September 25, 2018 On 13/08/2018 at 9:57 PM, MattyW said: Any recommend repairers in Brisbane? I'm wanting to replace the OPAMPS in my Weilang AKM 4497EQ DAC with trannys, and possibly change the power supply from 220v to a proper 240v one Expand In theory we now live in a 230V country so changing the PS around might not change very much.
MattyW Posted September 25, 2018 Posted September 25, 2018 On 25/09/2018 at 1:56 PM, Audiofix said: In theory we now live in a 230V country so changing the PS around might not change very much. Expand Nah, 250v at the wall here
att23 Posted October 22, 2018 Posted October 22, 2018 Hi all, I am a newbie especially when it comes to turntable and repair. I have a loose (green) ground wire that came undone from under the tonearm, hence constant hum/hissing noise. In my mind, I think it may be a simple repair/ soldering job for someone with the right tools/equipment. The annoying thing is that the super thin wire is manufactured quite short and my fingers are not delicate enough to fiddle with it, while tilting open the turntable base at same time. I don’t even have a magnifying glass. Anyway, from quick scanning of the thread, I assume the following ppl can do the job? Any other recommendations? Kimil Electronics, Rage Audio, JVP service centre Any idea roughly how much? Any other advice appreciated.
Guest jakeyb77 Posted October 22, 2018 Posted October 22, 2018 On 22/10/2018 at 12:23 PM, att23 said: Hi all, I am a newbie especially when it comes to turntable and repair. I have a loose (green) ground wire that came undone from under the tonearm, hence constant hum/hissing noise. In my mind, I think it may be a simple repair/ soldering job for someone with the right tools/equipment. The annoying thing is that the super thin wire is manufactured quite short and my fingers are not delicate enough to fiddle with it, while tilting open the turntable base at same time. I don’t even have a magnifying glass. Anyway, from quick scanning of the thread, I assume the following ppl can do the job? Any other recommendations? Kimil Electronics, Rage Audio, JVP service centre Any idea roughly how much? Any other advice appreciated. Expand What type of arm is it firstly? You may get it repaired but may be a small amount more and easier to do a full re-wire. That way it’s fixed and you get an upgrade. Win/win.
att23 Posted October 22, 2018 Posted October 22, 2018 On 22/10/2018 at 12:37 PM, jakeyb77 said: What type of arm is it firstly? You may get it repaired but may be a small amount more and easier to do a full re-wire. That way it’s fixed and you get an upgrade. Win/win. Expand I have the EAT B-Note tonearm, came with the turntable I bought not so long ago brand new. So I don’t think I need any full rewiring yet...? It’s my 1st turntable, I’m learning very slowly, so happy to be told I’m wrong. Come to think of it, I may be able to claim warranty. I shall ask if I can get it fixed locally or I have to pack and send interstate etc which could be a pain. Tbh, if it’s cheap, I am happy to get it fixed locally and bare the cost myself.
BLAH BLAH Posted October 22, 2018 Posted October 22, 2018 On 14/08/2018 at 1:28 AM, Spider27 said: My dumbness. I totally forgot to look at previous pages. Now I am having different kind of trouble whom to contact out of all. + CVE Electronics + JLS Electronics + Electronics Repair shop + Open Ear Audio + Clarke Audio Clarke Audio website looks like dealing with high end audio gear so might pass. The rest of 5 all seems fine. Amp itself is worth about $100 so do not want to spend much. I might contact from Ascending order and see how it goes. Thank you.. Expand Don't know about Dallas Clarke simply doing high end audio... Fixed up my little Sui au-101 beautifully... Worth a call...
Dean Gale Posted October 22, 2018 Posted October 22, 2018 On 27/07/2018 at 11:41 PM, Unsound said: Hi Guys, Does anyone know of a reputable specialist to repair an old REL Sub - Strata II? It has a buzz/hum - even when not connected to the amp. I have tried different cables and even connected to a PS Audio P10 power supply - no change? Thanks, MalcolmYou need to say where your located mate
Guest yamaha_man Posted October 22, 2018 Posted October 22, 2018 One word of advice, stay away from Dallas Clarke.
Guest jakeyb77 Posted October 23, 2018 Posted October 23, 2018 On 22/10/2018 at 11:39 PM, yamaha_man said: One word of advice, stay away from Dallas Clarke. Expand That’s 5 words
BLAH BLAH Posted October 23, 2018 Posted October 23, 2018 (edited) On 22/10/2018 at 11:39 PM, yamaha_man said: One word of advice, stay away from Dallas Clarke. Expand Top bloke...never had any problems! DClarke is his own man and you have to learn to deal with that! Edited October 23, 2018 by BLAH BLAH 1
Guest kab Posted October 23, 2018 Posted October 23, 2018 On 22/10/2018 at 11:39 PM, yamaha_man said: One word of advice, stay away from Dallas Clarke. Expand +1
Guest yamaha_man Posted October 23, 2018 Posted October 23, 2018 (edited) On 23/10/2018 at 12:34 AM, BLAH BLAH said: Top bloke...never had any problems! DClarke is his own man and you have to learn to deal with that! Expand He had my monoblocks for over a year! Damaged them (cosmetically) and put jaycar caps in them. Had to take them to someone who knew what they were doing who had a little bit of passion. Dallas Clarke can suck my ......... More than happy to discuss my opinion twith anyone including Dallas over several beers. Dont let his charm and charisma fool you. He is only after easy repairs to generate as much profit is he can. **** Clarke Audio. Edited October 23, 2018 by yamaha_man
Zaphod Beeblebrox Posted October 23, 2018 Posted October 23, 2018 On 13/08/2018 at 9:11 PM, Snapper() said: On 10/08/2018 at 1:14 AM, dammers31 said: I keep watching this thread.. I need to get a Sansui AU-419 recapped - well I think I do, it has gone into Protection Mode. I had hoped in Melbourne. Any recommendations? Expand Very common on these amps. You can buy the relay on ebay easily enough Expand A relay is not likely t be the problem. An AU-419 entering protection mode could be caused y a dozen different things. 2
Wimbo Posted October 23, 2018 Posted October 23, 2018 Its soo funny sometimes. People think all repairs must be cheap and techs work for peanuts. My take on it is... If you want a good job done by a good tech then you need to pay him or her good money. If not, we would have no techs. 2
BLAH BLAH Posted October 23, 2018 Posted October 23, 2018 On 23/10/2018 at 1:41 AM, yamaha_man said: He had my monoblocks for over a year! Damaged them (cosmetically) and put jaycar caps in them. Had to take them to someone who knew what they were doing who had a little bit of passion. Dallas Clarke can suck my ......... More than happy to discuss my opinion twith anyone including Dallas over several beers. Dont let his charm and charisma fool you. He is only after easy repairs to generate as much profit is he can. **** Clarke Audio. Expand And i have given you my opinion as well...
