rothman67 Posted December 15, 2022 Posted December 15, 2022 Hello All, I have an Onkyo TX-SR875 that has is randomly cutting out after about an hour or so use. Does anyone know of a good repairer / shop around the Blacktown NSW area? that could repair the AVR for me?. Thanks.
Milioli Posted January 5, 2023 Posted January 5, 2023 On 15/12/2022 at 10:34 PM, rothman67 said: Hello All, I have an Onkyo TX-SR875 that has is randomly cutting out after about an hour or so use. Does anyone know of a good repairer / shop around the Blacktown NSW area? that could repair the AVR for me?. Thanks. Hi, This looks like the old HDMI issue, very common on Onkyo and Denon at this era. I would recommend https://www.speakerhospital.com.au/ as they have some very good technicians there. But I am not sure will be worth fixing. Good luck!
SCRUFFO5 Posted January 7, 2023 Posted January 7, 2023 Hi I have 2 x Dali SWA 15 subwoofer drivers that need the speaker tinsels replaced. I am located at Cooranbong can anyone recommend anyone around Newcastle/Central Coast please.
Plzzz Posted January 13, 2023 Posted January 13, 2023 Hello i have a prima Luna evo 400 pre amp it has no 12 v trigger I would like to add one does any body have a suggestion? is there any really top electronic company that could assist I am in Melbourne.
Plzzz Posted January 13, 2023 Posted January 13, 2023 Hello I like to add a 12v trigger to my prima Luna evo 400 can someone please recommend a top electronic place in Melbourne I want it on the preamp.
keyboardman_uk Posted January 13, 2023 Posted January 13, 2023 Hi everyone. Hope you are well? Does anyone know where I can find a suitable repairer for my Marantz ST 300 tuner ? Many thanks for any advice. Richard
5L15 Posted January 14, 2023 Posted January 14, 2023 @keyboardman_uk check this thread out, best to start from the last page and work your way back and keep an eye out for Melbourne tech’s
Gee Emm Posted January 16, 2023 Posted January 16, 2023 On 09/11/2022 at 6:35 PM, Special K said: Has anyone had work done with Colin from Total recoil? I’m trying to find someone to work in the JR’s I picked up as the drivers need some work. Re one and a couple of burnt out tweeters. I also wouldn't ever recommend Total Recoil. In fact I would recommend you run in the other direction as fast as you can. This is based on 2 first hand & 1 second hand experiences. 2 2
Fenda Posted January 16, 2023 Posted January 16, 2023 Maybe this would work https://www.jaycar.com.au/amplifier-remote-signal-switcher/p/AA0419
blybo Posted January 16, 2023 Posted January 16, 2023 even better https://www.jaycar.com.au/4-way-smart-wifi-mains-powerboard-with-2-usb-ports/p/MS6107?pos=1&queryId=69a587b518b9a7f387a4d79a6c424fe7 There also used to be powerboards that would turn a connected device when other switched on. Not sure if still available
Milioli Posted January 17, 2023 Posted January 17, 2023 On 13/1/2023 at 4:57 PM, Plzzz said: Hello I like to add a 12v trigger to my prima Luna evo 400 can someone please recommend a top electronic place in Melbourne I want it on the preamp. I may be able to help you as I did an external 12V trigger to my amp very easily. And I don't know much about electronics. I'll PM you soon. Cheers
mackem Posted February 15, 2023 Posted February 15, 2023 After having really bad experiences with trying to get my diy power amplifier looked at, I found @Monkeyboi on this platform who has done tremendous work to get my amplifier sounding better than ever before. His attention to detail and his keeping me informed of the progress was very reassuring. Fantastic job. Before and after photos roger 6 1
Antipodean Brad Posted February 15, 2023 Posted February 15, 2023 (edited) No offense intended, but this topic needs a more appropriate title. Amp. looks great - now. Edited February 15, 2023 by Antipodean Brad 1 1
mackem Posted February 15, 2023 Posted February 15, 2023 I meant to have listed this in the recommend audio technician section but it ended up here. Can’t seem to move it
Monkeyboi Posted February 16, 2023 Posted February 16, 2023 10 hours ago, mackem said: I meant to have listed this in the recommend audio technician section but it ended up here. Can’t seem to move it I think one of the admins moved it for you. Thank you for the recommendation. Most appreciated. I was pleased to read that you are very happy with the result of the work on your amplifier. My aim is to ensure customers are completely satisfied with the work performed on their equipment. BTW, I don't just fix amplifiers (pre-amps, power and integrated), I also repair (solid state and tube gear) - DACs, tuners, CD, SACD players and transports *, turntables, phono pre-amplifiers, headphone amplifiers, cassette decks (including head alignments and Dolby calibration using professional calibration tapes), DCC decks, DAT decks, reel to reel machines, 8-track decks, graphic equalizers, quadraphonic decoders, some noise reduction units (Dolby, dbx, ANRS and adres), power supplies, loudspeaker crossover networks, some network streamers, PCB trace repairs, musical instruments (guitar amps, PA amps, mixers and Fender Rhodes pianos) even your audio / digital interconnect cables and vintage radios. I can also perform upgrades and modifications to customers' requirements (including re-capping); and can assist you with the electronics side of your DIY project builds including surface mount devices most DIYers aren't confident enough to tackle themselves. Don't send your vintage hi-fi to landfill because other mainstream repairers won't or can't repair it. Most equipment can be diagnosed to the component level then repaired and / or restored. If you have any questions just message me. * If you are in the Perth metro area I recommend you contact @rockeater for CD and SACD repairs as this is his area of expertise. 6
rockeater Posted February 16, 2023 Posted February 16, 2023 (edited) 12 hours ago, Monkeyboi said: My aim is to ensure customers are completely satisfied with the work performed on their equipment. These 2 pictures are the most impressive "before and after" that I have seen in a long time. You are a real pro. 12 hours ago, Monkeyboi said: If you are in the Perth metro area I recommend you contact @rockeater for CD and SACD repairs as this is his area of expertise. Thanks for the kind words, but the thing is that in my semi-retirement, I only dabble with CD players on a part-time basis in my garage, and prefer to buy faulty players, fix them and then sell on eBay or elsewhere. But I am happy to offer advice on what is the likely cause of a fault and how to fix it. Having said that, if a player is unusual or rare or interesting in some way, I tend to be much more easily convinced to take it on Edited February 16, 2023 by rockeater 1
Monkeyboi Posted February 16, 2023 Posted February 16, 2023 53 minutes ago, rockeater said: These 2 pictures are the most impressive "before and after" that I have seen in a long time. You are a real pro. Thanks for the kind words, but the thing is that in my semi-retirement, I only dabble with CD players on a part-time basis in my garage, and prefer to buy faulty players, fix them and then sell on eBay or elsewhere. But I am happy to offer advice on what is the likely cause of a fault and how to fix it. Having said that, if a player is unusual or rare or interesting in some way, I tend to be much more easily convinced to take it on Thank you Roman for the accolade. The F3 was an interesting re-build of a Tim Rawson build. There are more pictures over here Rebuilt: Dodgy DIY Projects One can only do as much as the original permits in terms of the mechanics of the device (chassis, heatsinks etc). In an F3 monoblock (one of a pair) I had a bit more latitude and space to replace a dodgy PCB with a new one I made in the workshop. I have seen some of your videos repairing CD players and found them quite interesting. You have repaired some interesting units that I suspect we don't see that many off.
Special K Posted February 27, 2023 Posted February 27, 2023 Hello, Just checking if anyone has any reviews/thoughts on the work done here, Thornbury Speaker repairs | Melbourne VIC | Facebook Just looking to get some surrounds done as I tried and failed on a pair. Not miserably, just a bit of rattle in one of them. Thank you in advance
manteios Posted March 2, 2023 Posted March 2, 2023 Dear all, I am looking for a technician in Hobart (or Tas more broadly) who could competently service my Luxman L-560. Any suggestions would be much appreciated. Thanks you!
philsailor Posted March 23, 2023 Posted March 23, 2023 Hello I am interested by the schema of the KT88-K3. I see that this amp don't use Ultralinear Taps on the output transformer. Is it possible to have the characteristics of the output transformer (mainly the input impedance) or the reference of the output transformer. Thanks for your help. Philsailor in Paris
Paul56 Posted April 2, 2023 Posted April 2, 2023 Hi All . For anyone in Melbourne I would be more than happy to recommend Jim at Filatronics in Oak Park . https://www.filatronicsavservice.com Very knowledgeable ,old school technician . Recently had him perform some mods on my PSAudio DAC . Excellent work , quick turnaround and very easy to deal with . 1
Axl Posted April 2, 2023 Posted April 2, 2023 1 hour ago, Paul56 said: Hi All . For anyone in Melbourne I would be more than happy to recommend Jim at Filatronics in Oak Park . https://www.filatronicsavservice.com Very knowledgeable ,old school technician . Recently had him perform some mods on my PSAudio DAC . Excellent work , quick turnaround and very easy to deal with . Nice. He would be very close by to me. But on his website it stated all the current brands and so I assumed that he /Filatronics do not work on older hifi equipment.
Special K Posted April 3, 2023 Posted April 3, 2023 On 2/3/2023 at 5:55 PM, manteios said: Dear all, I am looking for a technician in Hobart (or Tas more broadly) who could competently service my Luxman L-560. Any suggestions would be much appreciated. Thanks you! You maybe better off finding someone in Melbourne/Sydney. It will be interesting to see any recommendations that do come up closer to you. 1
