shogun2 Posted September 24, 2016 Posted September 24, 2016 Item: Cool Components HiFlow Vent SystemLocation: Blackwood, SAPrice: $200 Item Condition: Band New - In original boxReason for selling: Bought for a project that never got off the groundPayment Method: Pickup - Cash, Paypal, COD OnlyExtra Info: This unit was designed to circulate air in a room or closet where warmer air accumulates to another area in the home. Often times when components are installed in a closet, or even in the room where they are installed, the entire room or closet requires venting to circulate the warmer air. This unit is perfect for room to room venting and can be easily retrofit. This system will usually be installed on a wall adjacent to a hallway or larger area in the home and air will simply be moved from the closet, directly through the wall, to the adjacent area. This method of cooling helps to better circulate the air in the home and during cooler months, the warmer air is effectively used in heating the home and in warmer months, HVAC systems are designed to 'reprocess' warmer air and conditioning air that is simply heated is significantly more efficient than cooling and dehumidifying air which would be the case if venting to the outside or to attics. When venting outside, that air is replaced by air from the outside or most commonly and worse, air from the attic. This air can be hot, humid, and smelly so you should NEVER vent to the outside or to the attic! Features Aggressively Vents Rooms, Closets, or Larger Cabinets Complete Package for Easy Design & Ordering Quiet & Efficient Operation Features Levitation Fans Includes the New TC-ALTv2 Temperature Controller for Automated Control of On/Off and Fan Speed based on Temperature - 3 Selectable Modes for Different Applications Uses “Fast Wire” System for Trouble-Free System Design and Installation Includes Fan Unit, 2 Grills, Extension Cable, Advanced LTv2 Temperature Controller (TC-ALTv2) and Power Supply General Specifications Dimensions - Plastic Grill: (L x H): 260mm x 127mm Dimensions - Fan Unit: (L x H x D): 248mm x 114mm x 41mm Installation Cutout: (L x H): 205mm x 95mm Construction: Metal Fan Bracket / Plasitc or Wood Grill Options Fan System: 2 - 92mm Brushless Magnetic Levitation Fans (Est. 60,000 hrs.) Air Flow: Up To 130 CFM Noise: Silent to ~36 dba https://www.amberonline.com.au/products/cool-components/CB-VS-HFS-WHT Pictures
