huddo290 Posted November 19, 2016 Posted November 19, 2016 (edited) Have just hooked up a powered subwoofer using high level inputs as stereo is old and hasn't got subwoofer outputs. There is sound coming from sub but not very loud. The high level inputs does say "Input 2 From Amplifier" does this mean that I need to run it through an external amplifier before the sub even though it is a powered subwoofer?? I tried the sub on a newer system with the low level input and the sub worked perfectly. Any advice would be much appreciated. Edited November 19, 2016 by huddo290 Spelling Error
aasza Posted November 19, 2016 Posted November 19, 2016 The specific brands/models of the components you are using would help, ie.. amp/speakers/subwoofer
huddo290 Posted November 19, 2016 Author Posted November 19, 2016 AIWA Z-585 Stereo XMS-100 powered sub
andyr Posted November 19, 2016 Posted November 19, 2016 27 minutes ago, huddo290 said: Have just hooked up a powered subwoofer using high level inputs as stereo is old and hasn't got subwoofer outputs. There is sound coming from sub but not very loud. The high level inputs does say "Input 2 From Amplifier" does this mean that I need to run it through an external amplifier before the sub even though it is a powered subwoofer?? I tried the sub on a newer system with the low level input and the sub worked perfectly. Any advice would be much appreciated. I would've thought a powered sub would have RCA (line-level) inputs ... plus, it would have a LP filter (with a frequency knob) to roll the sub off at whatever frequency you select? That's the way my (powered) subs work, anyway. Andy
aasza Posted November 19, 2016 Posted November 19, 2016 (edited) You have to connect your speakers to the 'Output To Speakers" on the subwoofer Amp --> Input 2 --> Output To Speakers Edited November 19, 2016 by aasza
huddo290 Posted November 19, 2016 Author Posted November 19, 2016 9 minutes ago, aasza said: You have to connect your speakers to the 'Output To Speakers" on the subwoofer Amp --> Input 2 --> Output To Speakers Still the same. Is it possible that the "Input 2" bypasses the subwoofer amp and is just a straight through feed to the Sub speaker??
aasza Posted November 19, 2016 Posted November 19, 2016 (edited) No, normally the high level input takes the whole range of frequencies from the amp, the sub then handles the low frequencies and the higher frequencies are sent to the speakers for processing. However this is only really effective if you are using full range speakers Have you tried setting the high cut to 180Hz ? What speakers are you using ? Edited November 19, 2016 by aasza
