andyr Posted December 27, 2024 Posted December 27, 2024 9 hours ago, blownaway said: it may even get better with a cloth over the TV It will! But I suggest the 'cloth' should be something thick ... like a blanket. 2
DazzS Posted December 27, 2024 Posted December 27, 2024 Would one of those removalist blankets from bunnings do the trick? 2
Grimmie Posted December 27, 2024 Posted December 27, 2024 great idea but a bit ugly. 50mm foam from Clark rubber covered with a nice cloth (from Temu or Spotlight) like below (except that's Autex Acoustic 50 sound panel) bend a couple of hooks to fit over the top of the screen and into the foam out of plastic covered metal clothes hangers, - much prettier and more effective. 4
andyr Posted December 27, 2024 Posted December 27, 2024 56 minutes ago, DazzS said: Would one of those removalist blankets from bunnings do the trick? Absoloootely! 1
russell66 Posted December 28, 2024 Posted December 28, 2024 Listening to this old Thorens 166 mk2 tonight. I think the tonearm is a TP11 perhaps. Absolutely wonderful. There’s a reason people don’t do blind test with turntables. Yes they may sound different, but is that really better? 13
April Snow Posted December 28, 2024 Posted December 28, 2024 I just use 2 x Black fleece blankets from Kmart - I layer them over my TV - as they are black they do not look ugly (no different to a TV screen turned off) and they are light weight enough not to put too much weight on the TV Brackets on the wall. They are effective. And cheap as chips. Also I can fold up and put in the cupboard when not in use. They do make a difference when playing music. 9
dwbasement Posted December 28, 2024 Posted December 28, 2024 Made some room to fit the dac and cassette player under the amps. 21 2
April Snow Posted December 28, 2024 Posted December 28, 2024 4 hours ago, SPR08Y said: Aaahhh!!! Back from the shops… I love this looks so warm and inviting 3
mrbugeyes Posted December 28, 2024 Posted December 28, 2024 Greetings. What is the brand of the speakers. Cheers - M.
SPR08Y Posted December 28, 2024 Posted December 28, 2024 2 hours ago, mrbugeyes said: Greetings. What is the brand of the speakers. Cheers - M. ELAC BS244s
mwhouston Posted December 30, 2024 Posted December 30, 2024 With half a dozen recently finished DIY tube preamps and power amps I have plenty of combos to try out. Here “Elements” - Gold Lion 12AX7 SRPP preamp and “retro-Zen” EL84 power amp combo. Not combo I’ve tried before. On a short listen could be in-system for a while. http://retro-thermionic.blogspot.com/2024/10/retro-zen-decware-inspired-6bq5el84.html http://retro-thermionic.blogspot.com/2024/07/elements-12ax7-srpp-preamp-with-remote.html 11
hughmc2 Posted December 30, 2024 Posted December 30, 2024 On 28/12/2024 at 4:51 AM, SPR08Y said: Aaahhh!!! Back from the shops… See ! you can have style, and be tidy, and still be an audiophile 4 1 1
blakey72 Posted December 30, 2024 Posted December 30, 2024 (edited) My busy loungeroom/system/systems.. So the Focal Aria 936's handle 2 channel driven by the Exposure Classic XXVII dual monoblock and Exposure 2010S2 as a pre. The Whatmough's beside, middle and rear HT. Driven by the Marantz SR5013 with the fronts running through the Plinius 9200 ht bi-pass. Takes some pressure off the Marantz. The Pro-ject X2 B and Pro-ject Phonobox DS3 B are actually a balanced connection and the noise floor is crazy. Rose Hifi RS250 streamer does everything I want and sounds spot on. Droplet cd player well what can I say. The Aurex PC-X88AD isn't too shabby either and gets some use. That filled in a bit of time listening to Brothers in Arms PS - oh dear, yes that's myself and my lovely Mrs in the pic on the Marantz. I'm the one with the rough head! Edited December 30, 2024 by blakey72 14
mwhouston Posted December 30, 2024 Posted December 30, 2024 6 hours ago, hughmc2 said: See ! you can have style, and be tidy, and still be an audiophile Agree, just because you have a ton of gear doesn’t make you an audiophile. It definitely doesn’t make you a music lover. Confused maybe. 2 1
scuzzii Posted December 31, 2024 Posted December 31, 2024 On 28/12/2024 at 2:08 PM, April Snow said: I just use 2 x Black fleece blankets from Kmart - I layer them over my TV - as they are black they do not look ugly (no different to a TV screen turned off) and they are light weight enough not to put too much weight on the TV Brackets on the wall. They are effective. And cheap as chips. Also I can fold up and put in the cupboard when not in use. They do make a difference when playing music. and should you get cold, they have a secondary purpose 2
oukouk Posted December 31, 2024 Posted December 31, 2024 4 hours ago, blakey72 said: My busy loungeroom/system/systems.. So the Focal Aria 936's handle 2 channel driven by the Exposure Classic XXVII dual monoblock and Exposure 2010S2 as a pre. The Whatmough's beside, middle and rear HT. Driven by the Marantz SR5013 with the fronts running through the Plinius 9200 ht bi-pass. Takes some pressure off the Marantz. The Pro-ject X2 B and Pro-ject Phonobox DS3 B are actually a balanced connection and the noise floor is crazy. Rose Hifi RS250 streamer does everything I want and sounds spot on. Droplet cd player well what can I say. The Aurex PC-X88AD isn't too shabby either and gets some use. That filled in a bit of time listening to Brothers in Arms PS - oh dear, yes that's myself and my lovely Mrs in the pic on the Marantz. I'm the one with the rough head! that's a warm and inviting setup.. 1
mwhouston Posted December 31, 2024 Posted December 31, 2024 5 hours ago, blakey72 said: My busy loungeroom/system/systems.. So the Focal Aria 936's handle 2 channel driven by the Exposure Classic XXVII dual monoblock and Exposure 2010S2 as a pre. The Whatmough's beside, middle and rear HT. Driven by the Marantz SR5013 with the fronts running through the Plinius 9200 ht bi-pass. Takes some pressure off the Marantz. The Pro-ject X2 B and Pro-ject Phonobox DS3 B are actually a balanced connection and the noise floor is crazy. Rose Hifi RS250 streamer does everything I want and sounds spot on. Droplet cd player well what can I say. The Aurex PC-X88AD isn't too shabby either and gets some use. That filled in a bit of time listening to Brothers in Arms PS - oh dear, yes that's myself and my lovely Mrs in the pic on the Marantz. I'm the one with the rough head! Some nice gear by the way. 1
Misternavi Posted January 2 Posted January 2 On 31/12/2024 at 3:40 AM, hughmc2 said: See ! you can have style, and be tidy, and still be an audiophile of all the gear crazy audio fools in the world, only 3% can keep it that neat. 3
SPR08Y Posted January 2 Posted January 2 5 minutes ago, Misternavi said: of all the gear crazy audio fools in the world, only 3% can keep it that neat. Isn’t always… 1
mwhouston Posted January 2 Posted January 2 When your main listening area is the lounge, neatness is like hiding, hiding gear that is. 1 2
April Snow Posted January 2 Posted January 2 (edited) I have all my gear besides the turntable in cabinetry - I hate seeing "boxes" - I only want to see the Turntable My family already think I am crackers as it is with acoustic panels up But my setup is also in the main living area so I like it neat, if I had a dedicated room I would do otherwise 100% I love the look of a good rack Edited January 2 by April Snow 7 4
stevoz Posted January 2 Posted January 2 46 minutes ago, April Snow said: I have all my gear besides the turntable in cabinetry - I hate seeing "boxes" - I only want to see the Turntable My family already think I am crackers as it is with acoustic panels up But my setup is also in the main living area so I like it neat, if I had a dedicated room I would do otherwise 100% I love the look of a good rack Let's face it Sue, we all love a good rack. Someone had to say it! 1 1 1
April Snow Posted January 2 Posted January 2 Just now, stevoz said: Let's face it Sue, we all love a good rack. Someone had to say it! This is the only place you can talk about racks and not get banned 1 5
rantan Posted January 2 Posted January 2 1 minute ago, stevoz said: Let's face it Sue, we all love a good rack. Someone had to say it! Said by one. Thought about by hundreds! 1 4
