Item: KEF R400b R Series Subwoofer
Location: SAVI Sysytems, 1168 Albany Hwy, Bentley, W.A.
Price: $2999  $1800
Item Condition: EX-Display stock - slight corner damage to external cabinet on bottom corner (see pics)
Payment Method: Direct Deposit, Paypal, Cash - Pickup in store, Visa, Mastercard with no fees or penalties.
Extra Info:
- This item shows cosmetic corner damage to the exterior bottom corner - this was caused from transit into store (see pics)
- Otherwise all in perfect working order with less than 5 hrs use
( it has been run for 5 hours to check that the external bottom corner damage is only cosmetic ).
click here for Information and review links for KEF R400b Subwoofer
The KEF R400b is a high grade award winning compact sub-woofer that sounds equally impressive whether used in a home cinema package or a high end audiophile Hi-Fi sound system.
The R400b subwoofer continues with the modern, polished external styling of the rest of the R series speaker range and also incorporates a brushed aluminium trim - this all combines to make it one of the most stylish looking subs I have seen pass through our showroom in the last decade.
KEF also understand that nowadays the look of a product in your room can be as important as the sound.
The R400b is incredibly compact so it fits into your room in a classy, elegant way - measuring a room friendly 365x330x351 mm it is easy to fit into any home theatre or Hi-Fi system without being a huge, ugly black box that dominates the room.
Internally the R400b consists of a reinforced  and solidly braced cabinet that houses two active opposed custom KEF 9” drivers. This set up is done so that both driver outputs cancel each other inside the cabinet thus minimizing vibration and consequently the muddy sound that uncontrolled vibration brings. Each of the custom KEF drivers are powered by a 250W internal digital amplifier - making for a total of 500W of power amplification built in to ensure low distortion and clean, accurate, fast bass across all practical volume ranges.
On the rear of the R400b sub there is not only your usual gain/volume and frequency click detent dials, but also with a rather unique 3 position Bass boost switch - this is at a very deep bass frequency of around 40Hz - this helps to ensure that you can tune the subwoofer into your room to make sure that you not only hear, but actually feel the lowest of low notes. This is, of course, the whole point of putting a subwoofer into your system.
Pictures:
