2 hours ago, Snoopy8 said:
By the way, my AVAST virus scanner blocked the url for the dock.  Please virus check your own system...
Thank you @Snoopy8 I am ok (I think) as I run linux. But I will check with others.
Also, I will check out that other thread. ?
Andy
21 hours ago, billy170468 said:
@Bilbo
Can you suggest one please?
Andy
This is the one I bought and it does a fine job.
https://www.ebay.com.au/itm/HI-END-100VA-Linear-Power-Supply-DC12V-5A-Ultra-Low-Noise-LPS-for-Audio-L163-33/111944028903?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
I have found docking stations sound better with really beefy power supplies hence my choice of this supply.
Mind you when I bought it the price was $50 less but still represents good value.
On 12/10/2019 at 8:09 PM, billy170468 said:
@Bilbo
Andy
I prefer an Australian one...
4 minutes ago, billy170468 said:
Ok. Does that mean I need two of them (One for the dock and one for the sms200)?
@Snoopy8
Andy
Yes if you go the way of a powered usb disk.  ?  And there is also the more expensive gold tuned versions of the PSU!  :shocked:   Once you discover the benefits of a LPSU, it does becomes a slippery slope.
I did try a powered usb, but not the configuration that Bilbo recommended.  My music was already on a NAS. My trial with the powered usb showed only a slight, if any, improvement and I decided not go that way.
9 minutes ago, billy170468 said:
OK @Snoopy8 does that make it three required? One for dock, one for sms200 and one for Fein DAC II ?
?  The Fein II does NOT require one!  :cool:
@Snoopy8
Andy
I also purchased one of these dual units after the first one as I needed more 12V supplies.  The Geisler LPS is no doubt very good but my pocket couldn't stretch that far for three of them hence the cheaper option.
https://www.aliexpress.com/item/32767844733.html?spm=a2g0o.productlist.0.0.14c662f6Za6Ipc&algo_pvid=d35f6cb6-d152-47cd-9ce6-491558b08f70&algo_expid=d35f6cb6-d152-47cd-9ce6-491558b08f70-1&btsid=1e9ce43f-b30c-4176-beeb-82fa69213080&ws_ab_test=searchweb0_0,searchweb201602_6,searchweb201603_52
