kelossus Posted August 12, 2017 Posted August 12, 2017 Item: JBL L212 and B212 ComboLocation: Ipswich QLDPrice: $1600Item Condition: Pretty goodReason for selling: MoneyPayment Method: Pickup - Cash, Paypal, COD OnlyExtra Info: Charge Coupled networks using Jantzen components built by Nigel AKA Green Wagon. Internally rewired. See thread below: Rebuilt subwoofer plate amp, every component replaced besides the tranny. All tracks resoldered. Larger Mundorf filter caps and bridge rectifier. This sub digs very deep. The plate amp was always a little underpowered hence on the 2nd hand market they are always blown. This one has been rebuilt. It would have been cheaper/better to use an aftermarket plate amp but I wanted everything original, possibly something the next owner can investigate if they want to but not required. Over $500 worth of parts in the plate amp. See thread below: http://www.stereo.net.au/forums/topic/87432-jbl-l212-bass-energizer-pic-heavy/#comment-1420563 These speakers have a fairly flat frequency response for a JBL of the 70's. Very admirably measured from 30hz - 20khz +. I will say without a doubt running the satellites full range without the sub they absolutely destroy the NS1000's in the lower octaves. That little 8inch woofer would punch a hole in the 12inch of the NS1000's. May not go as deep as the NS1000's due to cabinet being designed for an 70hz roll off but for an 8 inch with a 3inch voice coil, its killer. Also the 12inch woofer in the sub has a beasty 4 inch voice coil and the same magnetic assembly of the 15 inch JBLs of the era. Both the mid-bass and subwoofer drivers have alnico magnets. The mid-bass unit has been re-spidered and foamed by Gary Cawsey at a significant expense. The subwoofer cabinent and satellite speaker bases have been relacquered. The subwoofer is pretty much flawless with a small scratch on the face of the plate amp. The satellite bases are in very good nick with a few imperfections in the veneer where the furniture restorer had perform patch ups. Very very acceptable and better than most other pairs I have seen. Also the satellites are on castors.
Gremrock Posted August 12, 2017 Posted August 12, 2017 Great spot to play the LPs! Putting Linns isolation techniques to work. they look like fun speakers 1
kelossus Posted May 12, 2018 Author Posted May 12, 2018 7 minutes ago, Eddy Chong said: How much is the sub alone? Hi mate, sold these a while ago now. Wouldn't have parted with sub regardless. They need to go as a set.
