rosco99 Posted August 9, 2005 Posted August 9, 2005 I have a Creative Audigy 2 ZS Audio card and I need a 3.50mm mono to RCA cable to connect the Digital out connector to Digital In on my Amplifier. I have a 3.5mm to RCAadaptor for a coaxial cable but I only get sound to the Front L&R speakers. The 3.5mm plug has only two segments but picture of plug in Audigy instructions appears to have 5 or 6 segments. No Australian suppliers of Creative products know this plug. Any ideas where I might find it?
mtv Posted August 9, 2005 Posted August 9, 2005 There are several varieties of these cables, depending on the device you are connecting to. Creative say they are optional extras, however they don't list them as an accessory. Try this crowd. http://www.programmersparadise.com.au
curlytopg Posted August 9, 2005 Posted August 9, 2005 There are several varieties of these cables, depending on the device you are connecting to. Creative say they are optional extras, however they don't list them as an accessory. Try this crowd. http://www.programmersparadise.com.au <{POST_SNAPBACK}> I just asked this question to the guys yesterday at http://www.htcustomcables.com It is not listed on the website, but they will make them for you if you ask. price is the same as the mono subwoofer cable. These cables get good reviews from many on the forum, myself included. Curly
rosco99 Posted August 10, 2005 Author Posted August 10, 2005 I just asked this question to the guys yesterday at http://www.htcustomcables.comIt is not listed on the website, but they will make them for you if you ask. price is the same as the mono subwoofer cable. These cables get good reviews from many on the forum, myself included. Curly <{POST_SNAPBACK}> Thanks fellas, I contacted HTcustomcables who responded promptly and told me that my existing adaptor is correct and I need to look further at set up of the PCI card. Apparently a digital signal only needs a positive and negative. I will try further adjustments at home
