6 minutes ago, Grizaudio said:
How did you decide/select the throat angle on the adapter?
I made it the same as the angle for the top and bottom horn walls. That means a change in angle for the other axis, but that isn't so bad
ok nice, I guess I was wondering if you changed throat angle to the "ideal" for each driver.
Cheers - Build looks great.
What woofers are you running?
Have you considered going Active?
These are pancake drivers, so the phase plug comes right up to the flyscreen and they don't have a well defined exit angle. I prefer to go straight to the horn coverage angle, as full tractrix or exponential horns with narrow throat angles make the high frequencies way too narrow in dispersion
Faital 15PR400 woofers, they are by far the best woofers i have heard for this application. Sensitive and extension to 30hz in room reliably
At the moment they are running active through a driverack PA2, but it should be easy to do a decent passive crossover. It would be a waste to have a 100+db/w system and not be able to use low power tube amps with it 😁
Edited by oohms
Nice 👍 work.
I have considered using the Faital 15pr400. By all accounts a great performing and value driver. In modelling the driver responds quite well to EQ within its xmax.
I actually have a pair of 12pr300, B&C de250 and Seos waveguides to ‘do something with’.  But the project got put on hold after listening to my current cabs.
My current compression driver runs 20khz to 700hz. I have really enjoyed having a point source driver from 700hz up, it just sounds amazing, especially EQd to Harman curve.
if you would care to share some freq sweeps, clarity sweeps and spectrograms/waterfalls I would love to see them.
great work…
Dear Oohms,
I have been in owning of a pair of Klipsch Cornwall 3 for a long time and have been very enthusiastic about you so far. The dream of a Klipsch Jubilee I would never have been able to fulfill financially.  I find here in Europe for over 53,000 dollars completely is for me overpriced. Your construction plan of a Klipschhorn K402 has given me courage to try it too. so far I had only square things made of wood. the horn with its many angles has cost me here and there some nerves. The first listening test made me forget all troubles and the corners of my mouth grow up to my ears. I am just thrilled with it. I got myself a Celestion AXI 2050 for this purpose. Currently only tested with a simple capacitor 3.3uf upstream with a 300B tube amplifier. Final there should be once a DSP. And later still the matching folded bass horn too.
Dear Oohms, Thank You very much, to help us, make dreams come true.
With Best Regards from Boris
South Germany
Edited by steuersenkung
  • Like 5
  • Love 4
They look amazing! I'm glad i could be of help
You song recommendations are good too, the Zhao Peng track is one I listen to on this system from time to time
  • 1 month later...
This project has me encouraged enough to build these beautiful K402 replicas for my AXI2050. Hopefully I can pull it off. Excited 😆
Do you know where I can download the black  round phase plug for the Axi2050 shown on @steuersenkungpost above? Of if you have the file, could you please share? Thanks a lot.
Dear JeffMazon,
here you find my design for download:
https://www.thingiverse.com/thing:6143042
With Regards Boris
  • Love 1
  • 1 month later...
Getting close to the end of the project, I procrastinate a lot. But powering through, the speakers are assembled
Here they are in their final spots
  • Like 6
  • Wow 2
Running them actively crossed over with DSP is convenient, but too easy. Crossover design time!
Measuring the drivers in place with REW
Together with impedance measurements using a DATS, then using a nifty program called xmachina to iterate and come up with a couple of potential designs
Simplifying the design and sanity checking using xsim
Then putting together prototypes for a listening test
They sound amazing in place, and given the nature of the design, I don't think there is a substantially better design to be had. After a month or so of listening, I am happy
Because of the speaker placement and nature of this design, they will need equalizing to sound perfect. This design only gets the crossover point right and equalises the horn close to optimal.
Edited by oohms
I've updated the stereo stack to be all analog and include a pair of 31 band EQs to dial in the sound perfectly
To my ears, this sounds better than the initial DSP setup
There are several ways to dial this in. One is trial and error using REW and a measurement mic, another is using a behringer DEQ2496 to generate pink noise and to show the real time response from the mic while I twiddle with the EQ. The latter is what I have initially done
This is one of the most brilliantly OTT projects I've seen on here - I love the fact that they barely fit below your ceiling. 😂 Fantastic stuff. If I still lived in Newport I'd buy you a beer (or whatever) at the Junction Hotel for sharing this journey with us all! 👏
Thanks, i appreciate it.. the Junction is a short walk from here 😁
Crossovers are done! The TS sockets are to get a direct connection to the drivers, either for active amplification, or more measurements for future crossover development.
They are mounted onto masonite and screwed into the bracing on the back of the horns.. now I just need to upgrade the plinths and explore dust covers for the woofers at some point
Absolutely Impressive inspirational build and excecution , you should be very very proud.
Look forward to reading more on your progress and fine tuning.
Personally found tweets close to the 15” drivers gives vibrant snap and definition , does look snazzy ceiling mounted too.
Looks like you are using  JBL M2 Marquis danceclub comp drivers in the 402s , got some too but to my ears are not near field friendly etc after hearing several non titanium drivers.
Keep up up the splendid build and enjoy 😉
  • Love 1
Thanks! I have a pair of 2451J drivers with genuine SL diaphragms, but there is some kind of rubbing issue with the voicecoils on both that I cannot get right. One day..
Edited by oohms
  • 1 year later...
The speakers are still going strong, and haven't changed since last time
One of the woofers developed a crackle, but re mounting it a couple of times fixed the problem
I know youtube recordings are frowned upon, but here goes
I bought a 2w SET - Eric McChanson's 6FD7 amp - and it sounds lovely on these, even playing fairly loud
Then i decided to test an all tube signal chain, with a tube phono preamp
  • Like 6
The Daft Punk video sounds pretty spot on.  You tube audio vids work well enough to determine what’s going on ,  I think it’s rather handy and offers good insight , well done.
Been playing around with a similar 402 sized horn on top of the old La Scalas  ,
sounding much easier on the ears  via the large mid  horn.
Be nice to have another BMS Coaxial comp driver to play with in the workshop system as much prefer the point source arrangement over multiple horns for mids and highs.
  • Like 5
On 10/02/2025 at 7:32 AM, oohms said:
looking good! Which peavey horns are they?
The Peavey Horn Model is unknown, very vintage large format unit, however came loaded with the Peavey A/A - 4000T monster sized 4" voicecoil compression driver, a rare and surprising unit that to my ears sounds far superior for Hi Fi  to others i have on hand such as the normally famed genuine diaphragmed JBL 2240, 2241, 2425s.
  • Wow 1
Love it...and not a high-cost speaker cable in sight...! I've always invested in cabinets/drivers over cables and 'bling.'
The 402 horn could work nicely on a Belle Klipsch. I built one recently. This one was in 25mm birch ply, with American Walnut veneer. The Bill Woods conical horn was not mine, though have built a similar one.
Keep up the good work.
  • Like 4
  • Love 1
