The Carbon is an Audio Technica from what I remember. The Elys2 , not sure.
I would get in contact with the dealer and advise them that you are going to email Rega and complain about the cartridge.
Hopefully then you can get your money back and buy the Ortofon.
Yes you are correct. Audio technica tuned a bit. Elys in house rega. I Will even take the whole deck to rega for a test but not back to the dealer. I think they are retarted or perhaps they think i am
Guest Eggcup The Daft
It sounds like the hum is produced by proximity to the motor. I don't know about the new range, but in the old days Nagaoka cartridges were a cure for this issue...
2 hours ago, rantan said:
@martin64
If you are looking for a really nice and affordable MM cart , I urge you to try a Shelter 201. I much prefer it to the Denon DL 301 I was previously using
Interesting. I very much want to go up the ladder with my next cartridge and was thinking MC around $500 - $1000 but in the context of my system I'm not sure if its worth it. Would you say it outshines a Goldring 2100? In the end it isn't very expensive so it wouldn't preclude a more adventurous upgrade later.
Correct. The higher end Rega TTs employ a shield around the motor.
I havent heard the goldring before but all the info i read lately suggest that goldring is fastantastic. I want to move up to a moving magnet cartridge but first need to sort my TT
If it's motor hum, the most important thing is the shielding around the cartridge. You can't do a lot about the motor. Rega describe the new version of the Planar 2 as having
Quote
New 24v low noise, low vibration motor assembly and new PCB.
http://www.rega.co.uk/planar-2-2016.html
If it's not working with the same brand's cartridge without hum I'd say that is a pretty significant failure (I don't see them advertising this as a "back to the '70s sound" anywhere!)
I would insist on a refund.
any outcome from your dilemma with your rega yet?
Hi Wen i spoke again to Rega and it is currently at their service centre for testing. I will soon know whats going on.
sound good so far, hope outcome is as well
They just confirmed me that the tone arm is out of order. The automatic anti scating system does not work. They are awaiting a replacement from overseas.
Rega service department is actually very helpful and friendly. Puts a little more trust in their systems. I was the guy who bought the brand new dud..just my luck.
If it helps any, I bought a Planar 3 with Elys2 cart mid last year. Had a faulty cart out of the box - right channel was quieter by about 20% compared to the left.
Replacement Elys2 fixed it. That took a week - my fancy new deck rendered unusable for the first week.
Supposedly it it gets tested at the factory before getting boxed - not so sure about that.
  • 4 weeks later...
Rega replaced my my tonearm as this was causing the issues. Received it last week and tested it fully and now it sounds like a turntable. Brand new out of the box it came with issues. Luckily it was sorted by Jls electronics and their service was excellent. Highly recommended.
  • 1 month later...
Damn, I was hoping Rega's were a bit more stable than that. i just took my Rega Planar 6 back yesterday to see if issue with a clicking sound was a big deal. It was 2 months old. Very good service from CAV who thought it may be the belt. Replaced it there and then. Played today and no, sound still there. Will need to go back and told up to a month with hope can be two weeks. Bitterly disappointed to spend $$$ and have an issue like this. Happens I guess.
I should update my experience. CAV were great and sent *** to Synergy to explore the issue. They could also hear the sound and looked as if a motor change was required.
Actually received my Rega within a week. Synergy had cleaned out the motor and re-lubed parts with end result that it is now dead quiet and plays very well.
Pretty happy with outcome and quick turnaround.
@martin64 running an ortofon 2m bronze in my rega 2   , reconnected an ifi iphono2 phono stage, the ortofon mm sounds open and airy as a moving coil now, very nice
[mention=260485]martin64[/mention] running an ortofon 2m bronze in my rega 2   , reconnected an ifi iphono2 phono stage, the ortofon mm sounds open and airy as a moving coil now, very nice
Very nice. I would give Ortofon a try.
