https://www.whathifi.com/reviews/panasonic-dp-ub9000-review
what hifi review, as they call out a bit strange as what is touted as a universal disc player that it cant play sacd/dvd-a
also truthfully it is same in capability as a disc player as the much cheaper 820 player, the 9000 just adding analog outputs at a premium and would be only reason to consider this player.
Noticed that review awhile ago . What hifi always seems to leave out relevant facts from their reviews Al ; interesting read but prefer reviews that go to some trouble with actual measured specs like sound and vision . When you compare this 9000 to the pio 800 ; your paying double for sacd and dvd-a disc playback vs file playback of those codecs[ even double rate downloaded variants] . Build quality is strong in the pana too with double plate anti vibration ;centred drive ;  separate audio psu ; and even one for the dac - nice ; though maybe not to the extent of the pio ..
And pana hasn't put all its  cards on the table according to this review .
Quote
However Panasonic’s engineers did cryptically allude to some exclusive video features being added to the UB900 before its launch in October.
https://www.techradar.com/au/reviews/hands-on-panasonic-dp-ub9000-review
 I wonder if either of the pio's will get alexa or google home
Edited by cwt
38 minutes ago, Peter_F said:
Not sure if its been covered before but now that I'm too late to get in on an OPPO, how does the CAMBRIDGE AUDIO CXUHD UNIVERSAL DISC PLAYER rate?
https://www.westcoasthifi.com.au/product/cambridge-audio-cxuhd-universal-disc-player/
uses the same shared mediatek chipset the oppo used. my memories of cambridge and I owned 2 units buying them in preference to oppos and they were well supported. quality units. I remember reporting an issue and next morning there was a firmware update. cant ask for more...
the cxuhd looks quite a swish machine, but lacks any sort of analog. its a purely hdmi based machine.
Thanks Al.  It seems to be a bit pricey for just a purely HDMI based machine, making it quite limited.
  • 4 weeks later...
it seems the 9000 gets a couple of projector owner specific options that dont come on the lower priced 820 model. not sure the ramifications, if anyone comes up with something be sure to post.
Do you know what they are Al?   The 820 has settings for projector which  I presume are  to  calibrate  the   HDR  tone-mapping more accurately
no idea, not sure if the manuals for both are available  so can be compared. it would be good to know one way or other...
Wow, $1050 price difference between the 9000 and the 820!  With the 9000 priced at $1649 and the Pioneer at $1899, I find it quite staggering considering the Oppo UDP-203 was only $850.  Maybe I'm missing something here? ?
the 203 wasnt aiming to be anything outstanding analog audio wise. it was a primarily hdmi machine. the others eg the 9000 has XLRs and such and build I am reading is better than the oppo. price is often also related to volume... its likely a LOT more 203s were aimed to be sold vs the 9000 for instance that wont even be sold in the US.
The 820 manual gives nothing away but I get the feeling the HCX processor in the 9000 has fancy Lumagen style look up tables :cool: Then again that requires differing HCX processor algorithms per model which have improved since the 900..
Quote
Among the new developments in the HCX processor is the introduction of a “Dynamic LUT” (Look Up Table) system. The LUT technology is used extensively in professional post-production and broadcasting to ensure color accuracy. Until now, LUTs were fixed according to the color space used by the source; with this innovation, the HCX automatically monitors the average brightness level of a scene and uses picture analysis to dynamically load a LUT appropriate to that scene, Panasonic explained
https://hdguru.com/panasonic-might-bring-new-flagship-4k-ultra-hd-blu-ray-player-here/
Okay that makes sense.  Is the Panasonic UB820 considered to be at a similar level to of the Oppo 203?
Do you know if any direct performance comparisons have been done between the Pioneer UDP-LX500 and the Panasonic UB9000?   Both appear to have superb build quality, though the Pioneer is 2.5kg heavier and is $250 more.
nope more yumcha box mover typical, I had the 900 model which was more substantial but no oppo 203 (that had as well)
I read something somewhere saying in build both pio and pana 9000 boot the oppo 203. in performance portably be a while before we get direct comparisons .... since 9000 wont be going into us will limit what we get on it.
I've been playing with both Panasonic UB820 and Oppo 203 -  Panasonic has an  advantage over Oppo with its HDR management /Tone mapping. In fact it seems  so  effective and dead easy to use  I can't see anyone not  getting a  great outcome from HDR.
Next to the Oppo the Panasonic 820   feels a bit tinny  but the 9000 should be better.  PQ wise there is nothing too complain about with Panasonic although I did upgrade the Oppo power supply  to linear which did improve Pq a bit.  Need to do hard comparisons but first impressions with Panasonic 4K UHD is very impressive.    I tested the  up-conversion of the Panasonic  with a 2k bluray allowing the 820 to output at 4k.   Forcing it to output the native disc resolution (1080p) gave a noticeably better result where the Sony 760 electronics do a better job of up conversion - pretty  similar with what happened with the  Oppo.
I'm pretty sure I'll get the 9000. I am considering the pioneer, especially as has a region mod, but the Panasonic 820 is probably superior tone mapping wise. So if the 9000 has additional projector options, even better.
The 820 manual is pretty grud, and doesn't give a lot. The advanced HDMI settings do not show the options available for each menu item.
Plus I love the subtitle luminance on the Panasonic...
I am looking between this and the pioneer as I'm keenly interested in something with a heavy duty build and tougher optical drive. The pioneer elites are typically a player with no complaints that last a generation. The Panasonic premium is yet unknown.
I don't care about the analog circuitry and frankly think it is a waste of space and money. It is one thing I really appreciate about the Cambridge. No analog, no stupid apps, just a transport.
Edited by Mobe1969
Can you link to the power supply that you used... I have a couple of 203,s ....wouldnt mind trying this mod  in one..:)
http://www.oppomod.com
I bought the SE model with the Schottky diodes and  Nichicon capacitors.  There are cheaper ones on Ebay and Aliexpress .
When switching between the Panasonic and Oppo on 1080p material,   I noticed a slightly cleaner image with the Oppo which I put down to the linear PSU.   I also use linear PSU to power  Dune and Zappiti media players.
For HTPC, I've noticed quite considerable gains in PQ with linear PSU including most recently with Mac Mini .     But then there is Apple TV which seems  to get it right without any assistance in that regard.
Edited by Tasso
Thanks...:)
https://www.avforums.com/review/panasonic-dp-ub9000-review.15435
review from, steve withers of avforums,
I have so far not been able to identify any difference playback wise vs the 820 model. so unless have a shying to its basic box mover build there appears no reason to step upto the 9000. personally I do put some value to player build. and also the highlighted getting rid of that plastic front flap and touch sensitive buttons the 900 has is a massive bonus. he doesnt talk much of its analog capability  and in anycase without sacd/dvda capability thats a massive miss and cant see many just getting this thing for CD. otherwise for most hooking up via hdmi there is no other reasons can be seen to get the 9000 over the much cheaper 820 ?
interesting he highlights a couple of other things in the limited benefit of the tone mapping wiht a projector. and where preferring the tone mapping in his telly instead. wiht more display devices (tvs / projectors) coming with inbuilt tonemaping (and where it belongs in my opinion) not sure how much ongoing benefit there is for this.
good to see streaming apps. though not sure we get those. I remember the pana 900 with very basic app capability and outputing at 60hz which was plain stupid for 24p material. i dont know if thats been sorted out or not. most will probably stick with apple tv which is lot more abundant and capable otherwise.
Hmm. I wish there were good reviews on the pioneer 500. It does have i think some limited tone mapping, looking at the manual, but no one has really looked at it. Some people here have had test units.
I really want something with rock solid optical. I am hoping the 9000 will be better than the 820 and older 900 (which I have had some Blu Ray problems on)
I  have also ordered the disc stabilizer from Oppomod to see how far I can take the  Oppo picture quality.
Edited by Tasso
I can confirm that you can get full region free capability for UDP-9000/820 from https://www.regionfreedom.com.     In addition, POU's and Cinevania  can be disabled.  I just installed the enhanced firmware onto the 820 and it works like  charm.  The firmware is made specifically for the Mac address for each individual player.   I disabled firmware update notification on the unit and will need to download new firmware from the site if it needs upgrading in the future .  They seem to be up to date.
You have to apply to be a "contributor"  to access the firmware and I made a 50 Euro contribution.
Or if you have a universal remote control you can make it region free for DVDs free of charge. Panasonic haven’t changed their remote codes for this in over a decade!
How did you figure that Al?  He states that he found the unit more effective with his JVC X7500
It is limited in that he preferred the inbuilt in the telly, with the projector he found “more effective” but for “subtle improvements” quote unquote. And also talks of the “dilemma”. I also posted my own explanation in that I do believe tone mapping belongs in the display(as is happening) and for that reason not sure ongoing benefit of it ... But I already said all that and am just repeating myself now .... :)
