Hi, Does anyone know if there is a difference between the Gold '50' or Gold 'GX50'?
They're advertised as the Gold 50 but I've read a few reviews, dated between 2017 to 2012 where they're called GX50. Not sure if it's the same speaker.
Edit: solved: just found them both on the MA website
Edited by Rockymc
Ok I found both speakers on MA's site but all the specs are identical. Does anyone know if there is a difference, except in the name?
Gold 50 was the replacement for the GX50. Surface of the Gold 50 woofer has dimples kind of like a golf ball. GX50 woofer has radiating ridges. Gold 50 has a fabric grill while GX50 has a perforated metal grill. Otherwise they look the same. I don't know if they sound much different.
Thanks, so not much difference then. There's supposed to be a 'trickle down' of technology from the Platinum model but MA seem a bit shy about describing what that is.
