aussievintage Posted April 15, 2024 Posted April 15, 2024 1 minute ago, andyr said:  Wow! Can you possibly get a simpler circuit than that?  And does that count as 1 gain stage ... or 2? (IE. does it invert the signal... or not?)   It's one, as the output stage is a voltage follower. Yes it inverts the signal. 1 1
muon* Posted April 15, 2024 Posted April 15, 2024 I'll likely leave the board alone and sell the pre to someone that needs the gain level. 1
aussievintage Posted April 15, 2024 Posted April 15, 2024 1 minute ago, muon* said: I'll likely leave the board alone and sell the pre to someone that needs the gain level. Yeah fair enough.
Bisguittin Posted April 16, 2024 Posted April 16, 2024 (edited) I've just mounted a pair of Coral 12Tx-1's onto 7-ply open baffles. Driven by @mwhouston's 71A valve amp, the results are stunning! The imaging of these things defies belief and if their efficiency isn't well, well above 100db I'd be most surprised. Teamed with an REL T9I sub, the musical presentation is remarkable. Ry Cooder has never sounded so good. WAF is another matter of course and is probably unsustainable. I've bravely put these in situ while she's not at home..............o oh??? Is that a car door I hear? Edited April 16, 2024 by Bisguittin 3 1 4
mwhouston Posted April 16, 2024 Posted April 16, 2024 4 minutes ago, Bisguittin said: I've just mounted a pair of Coral 12Tx-1's onto 7-ply open baffles. Driven by @mwhouston's 71A valve amp, the results are stunning! The imaging of these things defies belief and if their efficiency isn't well, well above 100db I'd be most surprised. Teamed with an REL T9I sub, the musical presentation is remarkable. Ry Cooder has never sounded sp good. WAF is another matter of course and is probably unsustainable. I've bravely put these in situ while she's not at home..............o oh??? Is that a car door I hear? You could try a coat of paint starting with a quick sandpaper, prime and top coat with a roller. May enhance WAF. 1
Bisguittin Posted April 16, 2024 Posted April 16, 2024 2 minutes ago, mwhouston said: You could try a coat of paint starting with a quick sandpaper, prime and top coat with a roller. May enhance WAF. That's the plan Mark. Already poring over the Dulux decorator colour card. 3
mwhouston Posted April 16, 2024 Posted April 16, 2024 Talk about efficient. Â https://audio-database.com/CORAL/unit/12tx-1.html Â
mwhouston Posted April 16, 2024 Posted April 16, 2024 With OBs the other thing to try is stapling thick Dacron on the back to help control rear reflections. Easy enough to pull off if you don’t like it.Â
andyr Posted April 16, 2024 Posted April 16, 2024 4 minutes ago, Bisguittin said: That's the plan Mark. Already poring over the Dulux decorator colour card.  Nah - white! (So they will fade into the background and wifey won't notice them.)  2 2
muon* Posted April 16, 2024 Posted April 16, 2024 I was curious, so hard wired the power taking the switch and wires to and back from it out of the equation. Â Less but still hum close to the speakers. 1
ThirdDrawerDown Posted April 16, 2024 Posted April 16, 2024 3 hours ago, Bisguittin said: Already poring over the Dulux decorator colour card. Â Pink! You can always say it's a primer coat. 3
stereo coffee Posted April 16, 2024 Posted April 16, 2024 3 hours ago, Bisguittin said: I've just mounted a pair of Coral 12Tx-1's onto 7-ply open baffles. Driven by @mwhouston's 71A valve amp, the results are stunning! The imaging of these things defies belief and if their efficiency isn't well, well above 100db I'd be most surprised. Teamed with an REL T9I sub, the musical presentation is remarkable. Ry Cooder has never sounded so good. WAF is another matter of course and is probably unsustainable. I've bravely put these in situ while she's not at home..............o oh??? Is that a car door I hear? Looking good, as long as Leo, doesn't take on Chewing Pine 1
Bisguittin Posted April 16, 2024 Posted April 16, 2024 32 minutes ago, stereo coffee said: Looking good, as long as Leo, doesn't take on Chewing Pine Nice pick up Chris.
aussievintage Posted April 16, 2024 Posted April 16, 2024 1 hour ago, muon* said: I was curious, so hard wired the power taking the switch and wires to and back from it out of the equation.  Less but still hum close to the speakers.  Yeah, so probably would need a rebuild with power supply isolation/shielding etc to really fix it. Pity. 1
muon* Posted April 17, 2024 Posted April 17, 2024 Added a series resistor to the output RCAs, and this reduced gain slightly but also halved the hum/buzz. Â See how it goes once I add a resistor in parallel.
aussievintage Posted April 17, 2024 Posted April 17, 2024 42 minutes ago, muon* said: Added a series resistor to the output RCAs, and this reduced gain slightly but also halved the hum/buzz.  See how it goes once I add a resistor in parallel.  Think 'voltage divider'. This is basically what I was suggesting with the cathodee resistor of the output cathode follower. Only difference, you are doing it externally after the output cap, so the change in loading will effect the bass response slightly (maybe insignificantly) 2
muon* Posted April 17, 2024 Posted April 17, 2024 (edited) 4 hours ago, aussievintage said:  Think 'voltage divider'. This is basically what I was suggesting with the cathodee resistor of the output cathode follower. Only difference, you are doing it externally after the output cap, so the change in loading will effect the bass response slightly (maybe insignificantly) Yes.  Output impedance will be high, will see how it effects the response.  Edit: OK, With added resistors in parallel only the slightest hum/buzz if you put ear against speaker and listen carefully  Most of the gain reduced, so maybe only 3 or 4db gain now. Edited April 17, 2024 by muon* 1
andyr Posted April 17, 2024 Posted April 17, 2024 3 hours ago, muon* said: Yes.  Output impedance will be high, will see how it effects the response.  Edit: OK, With added resistors in parallel only the slightest hum/buzz if you put ear against speaker and listen carefully  Most of the gain reduced, so maybe only 3 or 4db gain now.  But what is the Zout now? Â
muon* Posted April 17, 2024 Posted April 17, 2024 (edited) 22 minutes ago, andyr said:  But what is the Zout now?  I think about 11k  Zin for my amp is 10k  Now you are going to say it needs to be one 10th of the input impedance of the amp or less. A guess that may be true or not  In practice I have found the above is not necessarily true. Edited April 17, 2024 by muon*
andyr Posted April 17, 2024 Posted April 17, 2024 (edited) 11 minutes ago, muon* said: I think about 11k  That's absolutely ridiculous!  11 minutes ago, muon* said: Now you are going to say it needs to be one 10th of the input impedance of the amp.  In practice I have found the above is not necessarily true.  In fact the equation is *maximum!* 1/10th.  I suggest the fact that you have found this 'rule' to be not necessarily true ... is simply that you were unable to hear any negatives, when you had a Zin that was <10x Zout. I can accept that the "10x rule" may not be absolute - but I myself do not care to break it.   Edited April 17, 2024 by andyr 1
muon* Posted April 17, 2024 Posted April 17, 2024 (edited) 23 minutes ago, andyr said:  That's absolutely ridiculous!   In fact the equation is *maximum!* 1/10th.  I suggest the fact that you have found this 'rule' to be not necessarily true ... is simply that you were unable to hear any negatives, when you had a Zin that was <10x Zout. I can accept that the "10x rule" may not be absolute - but I myself do not care to break it.   Your not a webble like I am  Edit: I was aiming for 10k but didn't have the resistor values at hand to get it. Had to consider the actual Zout of the pre amp circuit going into the voltage divider. Edited April 17, 2024 by muon*
andyr Posted April 17, 2024 Posted April 17, 2024 16 minutes ago, muon* said: Your not a webble like I am  "Webble"?? Â
andyr Posted April 17, 2024 Posted April 17, 2024 8 minutes ago, muon* said: Rebel  Aah, thanks Ian.  (I googled it ... but no help!)  1 1
Grimmie Posted April 17, 2024 Posted April 17, 2024 You know!!! Webble webble, you torn your dwess. (Apologies to David) 4
