///Matt Posted October 9, 2013 Author Posted October 9, 2013 Yes, running the LP12 into the P75. After hearing it mentioned in this thread I switched the P75 into Dr T mode, but I did it as I swapped in the Plinius so I am not sure exactly what difference it made over the standard setup and I haven't really had the chance to switch it back and compare. Next comparison will probably between the P75 and the inbuilt phono stage but I am so happy with the sound right now I'm in no hurry to do that! Glenn, a bit of a swap sounds good at some point. I am thinking I could probably do with some advice on making sure I have the LP12 set up absolutely correctly too. I'm always keen to do listening sessions as well, at the very least! Send me a PM sometime if you're keen to tee something up.
