Hello,
I’ve noticed that my Primare I22 amp is emitting a buzzing/humming sound. As a first step to identifying the problem should o consider moving it away from other components and my TV?
Any tips appreciated.
Thank you
8 minutes ago, amandhillon said:
Hello,
Thank you
So this buzzing/humming sound has just appeared?
Is the buzzing/humming coming only from the I22 (probably its power transformer) … or do you also hear something from your speakers?
But, yes, try moving it away from other things - particularly your TV!
Andy
Edited by andyr
7 hours ago, amandhillon said:
Thanks! The buzzing is only from the amp and not the speakers.
OK, then - that's good.  As you're in Melbourne, if you're interested, I could bring over a couple of my 'power devices' to see whether they remove the buzz from your amp.
PM me if you're interested.
(But move it away from the TV, first!  :) )
Andy
Edited by andyr
