Rockman Posted November 23, 2019 Posted November 23, 2019 I'm looking to make up some power cables & have some nice plugs but, now need the raw cable. Need some suggestions re good but, not too expensive cable a where to procure.
Decky Posted November 23, 2019 Posted November 23, 2019 See the search that I created in element 14 (newark) https://www.newark.com/w/c/cable-wire-cable-assemblies/multiconductor-cable/prl/results?cable-shielding=shielded&no-of-conductors=3conductor&wire-gauge=16awg&sort=P_PRICE You can try it yourself with different parameters. I used LAPP cable in the past https://www.newark.com/lapp-usa/2216030/shld-flex-cable-3cond-16awg-100ft/dp/69AC7450 You can see what suits your budget and needs. You can also use Belden 19364 power cable but that is already labled as "audiophile" so most of the ebay sources will charge extra because of that. There is also Belden 83803 PTFE jacketed shielded 12AWG cable. Awesome and very expensive but also impossible to work with and use especially on runs less than 3m.
david j Posted November 23, 2019 Posted November 23, 2019 Ive bought some lava cable caldera power cable made by beldin for about $3.50 usd per foot + shipping
Lochawe Posted November 24, 2019 Posted November 24, 2019 7 hours ago, Rockman said: I'm looking to make up some power cables & have some nice plugs but, now need the raw cable. Need some suggestions re good but, not too expensive cable a where to procure. Can you clarify what your "not too expensive" budget is ? Will help with recommendations. Which plugs will you be using? 1
HypnoToad Posted November 25, 2019 Posted November 25, 2019 Wouldn't the cheapest way would be to get some good quality 3 core cable, a roll of that copper foil tape and wrap it around the cable then put some shrink tubing over the top. Connecting the copper foil to the earth wire at one end. This would eliminate EMI? Copper Foil Tape
audiofeline Posted November 26, 2019 Posted November 26, 2019 2 hours ago, HypnoToad said: Wouldn't the cheapest way would be to get some good quality 3 core cable, a roll of that copper foil tape and wrap it around the cable then put some shrink tubing over the top. Connecting the copper foil to the earth wire at one end. This would eliminate EMI? Copper Foil Tape I was thinking a similar thing for a cheap mains lead, but slightly differently. Somewhat inspired (but different) to the VH Audio's approach to the DIY mains lead (without using fancy wires) - https://www.venhaus1.com/diymains.html Get a standard IEC cord, and cut off the 3-pin mains plug, leave the IEC plug. Wrap an insulated earth wire (green and yellow from bunnings) around the cable as a drain, heat-shrinking it to the IEC end so it is secure; do not connecting it to anything. Put small pices of heat shrink along the cable at regular distances (eg. 6cm) to secure the wrapped drain cable. Connect the additional drain wire to the earth of the mains plug end. Cover the entire cable with braided expandable nylon sleeving, secured at both ends with heat shrink. Connect the three mains leads with the drain wire to a quality Clipsal 3-pin mains plug. I'm not pretending that this will be the same quality as using a shielded cable with quality internal wires, but may reduce the EMI.
audiofeline Posted November 26, 2019 Posted November 26, 2019 2 hours ago, HypnoToad said: Wouldn't the cheapest way would be to get some good quality 3 core cable, a roll of that copper foil tape and wrap it around the cable then put some shrink tubing over the top. Connecting the copper foil to the earth wire at one end. This would eliminate EMI? Copper Foil Tape A question for those with knowledge of our electrical safety standards: Would heat-shink be considered appropriate insulation for this, or would it require more?
HypnoToad Posted November 26, 2019 Posted November 26, 2019 54 minutes ago, audiofeline said: A question for those with knowledge of our electrical safety standards: Would heat-shink be considered appropriate insulation for this, or would it require more? I would wrap the copper foil tape around the outside of the cable which includes the insulation, so I can see no problem with safety. Others may chime in with more info.
audiofeline Posted November 26, 2019 Posted November 26, 2019 3 hours ago, HypnoToad said: I would wrap the copper foil tape around the outside of the cable which includes the insulation, so I can see no problem with safety. Others may chime in with more info. Understood, in normal use the current cables would carry the voyage inside regular cable insulation designed for 240v. However, in the event of a failure, the earth cable could carry 240v, so in this event, the metal foil surrounding the inner insulation could also carry 240v. So the heatshrink would also need to protect against this current, and I'm thinking it's a lot thinner (and therefore more vulnerable) than power cable insulation. Hence my curiosity regarding it meeting electrical safety standards.
A9X Posted November 26, 2019 Posted November 26, 2019 7 hours ago, HypnoToad said: This would eliminate EMI? No.
A9X Posted November 26, 2019 Posted November 26, 2019 4 hours ago, audiofeline said: A question for those with knowledge of our electrical safety standards: Would heat-shink be considered appropriate insulation for this, or would it require more? Is the heat shrink suitably rated and installed correctly and tested before use? Most likely no.
Guest Muon N' Posted November 26, 2019 Posted November 26, 2019 HEATSHRINK DUAL WALL GLUE L 4.8-1.5 1.2M - XDW5BK | CABAC WWW.CABAC.COM.AU Technical Data Conformant Standards: UL: MIL-1-23053/4: JIS Material: Dual wall, flexible, flame retarded polyolefin with modified polyamide adhesive sealant Continuous operating temp: -55░C to +110░C Shrinkage temp: Starts at 90░C, completed at 125░C Tensile strength: 10.5 MPa Elongation at break point: 200% Longitudinal shrinkage: 15% Breakdown voltage: 20 kV/mm wall thickness Volume resistivity: 1.0 x 1014 ohm cm Water absorption: 0.5% Flammability: All tubing flame test: pass UV resistance: Passed-ISO 1408 Voltage rating: 600 V
A9X Posted November 26, 2019 Posted November 26, 2019 ^^ Doesn't change my last two points. It's a waste of money and energy to do what's proposed anyway. Shield still won't be contiguous.
Guest Muon N' Posted November 26, 2019 Posted November 26, 2019 8 minutes ago, A9X said: ^^ Doesn't change my last two points. It's a waste of money and energy to do what's proposed anyway. Shield still won't be contiguous. If you think I'm trying to change anything about you or ya' posts, you are bloody dreaming
A9X Posted November 26, 2019 Posted November 26, 2019 Then your reading and comprehension skills are poor, as that was not what I was inferring.
Guest Muon N' Posted November 26, 2019 Posted November 26, 2019 21 minutes ago, A9X said: Then your reading and comprehension skills are poor, as that was not what I was inferring. Love you too...kiss-kiss.
Hytram Posted November 26, 2019 Posted November 26, 2019 (edited) My understanding of electrical regs from 20 years ago (when I was an electrician and had far better memory) was any conductor carrying 240v AC not enclosed in a enclosure must be double insulated with insulation that is rated at double the voltage.. So if you have a single insulated cable and put heat shrink over it, as. Long at the heat shrink is rated at 480v or above then you are good. Seeing that the braid of braided power cable only has one lot of insulation over it I am 'assuming' that the double isolation rule doesn't apply to earthing cable. Also as my memory is returning, Seeing your main earth from your switchboard to your earth stake is single insulated cable, without looking at the regs I would say, earth, single insulation is OK. Most heat shrink in Australia would be rated at least 0.6kv (600v) If you are making your own power cables (naughty naughty) get yourself an insulation tester (megger) and learn to test them properly. It's deadly S-H-1-T **all information in this post is for entertainment value only and should not be relied on as fact. Edited November 26, 2019 by Hytram 1
Batty Posted November 26, 2019 Posted November 26, 2019 8 hours ago, Hytram said: If you are making your own power cables (naughty naughty) get yourself an insulation tester (megger) and learn to test them properly. It's deadly S-H-1-T **all information in this post is for entertainment value only and should not be relied on as fact. +1 on this. 1
Neo Posted November 26, 2019 Posted November 26, 2019 (edited) Unless you swapping the connectors on each end of the power cable or putting together one from three components (power connector, pre made power cord cable, iec). Any other activities/inventions are deadly and should be avoided. Above written for entertainment purposes only, as I buy cables already pre made and do not require reinventing the wheel, I mean power cord. Neo Edited November 26, 2019 by Neo
HypnoToad Posted November 26, 2019 Posted November 26, 2019 (edited) Never mind. Edited November 26, 2019 by HypnoToad
