Hytram Posted April 25, 2020 Posted April 25, 2020 Further information: advertising this on behalf of a mate, 1 owner from new, immaculately looked after and is in 99% cosmetically and operational condition he has raved about this to me for years and I alway said if he wanted to get rid of it, to give me first dibs... sadly, I cant afford it ATM its the twin 12.3" inch down firing version with a 900w BASH amp that you have the option to tune it to 25hz, 20hz or 16hz via foam plugs in the ports sure there are cheaper subs out there, but not this loud and LOW due to its size and weight it's a pickup only Manufacturer specs: • Twin SVS designed/built custom Plus 12.3 woofers • SVS designed, full-featured 900 watt BASH ® digital switching amp • Built-in, flush-mount amp configuration • Down-firing woofers with distinctive SVS integrated base-plate • Compliant floor mounts, ultra low center of gravity • Three tuned, patented 4” high-flow flared porting (in and out) • Assembled and tested by SVS in its Ohio factory • Extra heavy-duty detachable 8 foot power cord • Selectable 16Hz, 20Hz or 25Hz extension with included port plugs • Size: 48 cm wide, 67 cm tall and 71 cm deep. • Weight: 64 kg • Frequency Response: +/- 3dB to 20hz anechoic Photos:
