Reason for selling: clearing the decks
Includes postage
cable not included, though I have a pair of xlrs and speaker cables I believe you can use with this.
PRODUCT DESCRIPTION
The Entreq Minimus has a single dedicated ground point. Its capacity is generally limited to either 1 or 2 dedicated ground cables to ground your equipment, or for the use with Entreq signal cables. This can be with the digital, USB, analogue or speaker cables.
    Note : Where possible please ground digital & analogue cables to seperate ground points.
". . .food for thought in a general sense, a no-brainer as an audio upgrade." - Roy Gregory
Read the full Audio Beat review here.
"In my (very) humble opinion that's exactly what they are, utterly amazing. Like I said before they are the single most important upgrade I have carried out in my system." - Devialet Forum.
Entreq believe that grounding is one of the key essentials in acquiring excellent sound quality in any hifi system, but conditions vary greatly from place to place. Firstly, it depends on conditions in the ground where the soil takes place, partly on the amount of pollution discharged into the underground network.
Their ongoing research as well as extensive listening tests have proven conclusively that stable effective grounding can eliminate a multitude of noise, field effect & unwanted magnetic properties. After many years of research the team at Entreq released there own dedicated range of ground boxes & associated grounding cables. Each ground box offers specific levels of grounding, each relevant to the system or application required. Both the Minimus & Silver Minimus offer a single reference ground point only. This generally allows approximately two ground cables to be attached to a single box at any one time. The Silver Minimus offers a more effective ground point than the standard Minimus, with a lower noise floor being heard in the system.
Ground cables sold separately.
Note: Entreq Minimus can not replace protective ground.
Edited by Eagleeyes
