Kaynin Posted August 11, 2020 Posted August 11, 2020 (edited) Further information: Howdy, I'm selling my Audyssey pro cal kit, all accessories supplied are included. There's heaps of bibs and bobs, all working perfectly. I don't think you can purchase these anymore, happy to be corrected though. A licence is about $150 per unit, but the results are awesome. I've used it on 1x AVR and 1x pre-pro and the improvement over the standard plastic dicky Audyssey mic is A1. A massive step-up in quality, resulting in realistic adjustments first time around. I've used it about 3-4 times per unit, so not much at all. I have original boxing, so happy to post Australia wide at your cost. No matter how great the equipment in your home cinema, its performance is limited by the distortion caused by the acoustics of the room. The Audyssey Pro Kit allows you to get the best sound equalization possible from a Pro-Ready AVR or Processor and the process can be uniquely tailored to the room, system and seating configuration. The Audyssey Pro Kit includes a professional, custom-calibrated microphone and the MultEQ Pro PC application to customise and control the results for each room/system. With a few clicks, your home cinema system is calibrated to reference standards or your own custom target sound curves. The proper trim levels, distances, and crossover settings are calculated. MultEQ Pro is the PC software used to perform an Audyssey Pro calibration. It is part of the Audyssey Pro Kit which, together with a Laptop or PC, includes all the equipment needed to complete a calibration on any Pro-Ready device. A License is also required for your AVR or Processor, which is available to purchase on the Audyssey website after the Audyssey Pro Kit has been registered. Professional Audyssey Mic, individually calibrated to industry standard measurement microphone Up to 32 Mic positions collects more detail about the acoustical problems of the room, yielding more accurate results Crossover selection options allow for a more accurate sound blending between the Subwoofer and Satellite speakers Target sound options ensures that the sound can be better tailored to your room type, including 3 pre-sets, curve editor and Midrange Compensation on/off Adjust all three Audyssey Dynamic Volume pre-sets, to match the results to your listening preference Printable Certificate shows before and after responses for every speaker in your system The option to Save and Load measurements for comparison or backup Photos: Edited August 11, 2020 by Kaynin 1
