grasshoppa Posted August 15, 2020 Posted August 15, 2020 Can I use fleece which is 100 percent polyester as curtains for sound absorbing ? It is transparent I can breath through it. Thst right is it. To capture the sound waves. For better sound?
Irek Posted August 15, 2020 Posted August 15, 2020 It's much better than painted walls or glass (windows, doors).
Guest Peter the Greek Posted August 15, 2020 Posted August 15, 2020 Jersey is probably better... Have you looked at Trilogy 1?
grasshoppa Posted August 15, 2020 Author Posted August 15, 2020 Gday Peter. thank for your feedback. Have looked into Trilogy fabric. It’s says it’s good for acoustic panels as well. Comes in 1.8 width by 50 m roll. Will call them up tomorrow. thanks again.
LogicprObe Posted August 16, 2020 Posted August 16, 2020 Here's the link for others watching. https://www.innova.com.au/uploads/5ceca1761d13c.pdf https://www.innova.com.au/products/1-trilogy-1 Similar to some headlining fabrics used in cars. 1
jazzman1974 Posted August 22, 2020 Posted August 22, 2020 is the trilogy 1 available in less than 50m rolls? will be needing to cover some frames around my screen with fabric but wont be needing that much....
Guest Peter the Greek Posted August 22, 2020 Posted August 22, 2020 9 hours ago, jazzman1974 said: is the trilogy 1 available in less than 50m rolls? will be needing to cover some frames around my screen with fabric but wont be needing that much.... Yep. They sell it by the meter.....or at least they did
jazzman1974 Posted August 23, 2020 Posted August 23, 2020 6 hours ago, Peter the Greek said: Yep. They sell it by the meter.....or at least they did Thanks Peter, have sent them a message to find out
LogicprObe Posted August 25, 2020 Posted August 25, 2020 (edited) Just on the OP.............that fleece stuff would be bad for curtains, or most anything! Picks up all sorts of cling ons and a bugger to clean. Edited August 25, 2020 by LogicprObe
grasshoppa Posted August 25, 2020 Author Posted August 25, 2020 Thanks for thst. yeah I have decided to use jersey fabric. I got a sample of trilogy fabric but it’s really hard fabric.
Guest Peter the Greek Posted August 25, 2020 Posted August 25, 2020 2 hours ago, grasshoppa said: Thanks for thst. yeah I have decided to use jersey fabric. I got a sample of trilogy fabric but it’s really hard fabric. Makes it SO much better to work with. Doesn't fray, stretch etc. Lots of people use in front of speakers. Its great stuff.
grasshoppa Posted August 25, 2020 Author Posted August 25, 2020 Hi Peter are you talking about the Trilogy fabric, i want to make drapes i think it would look terrible that fabric as drapes it wouldn't drape down very well if you know what i mean. I will use it for acoustic panels ! I will use Jersey fabric for drapes!
LogicprObe Posted August 25, 2020 Posted August 25, 2020 The way to go is to use any fabric you want on the 'viewing' side, sunblock fabric on the window side and whatever wadding you fancy/can afford in between. https://www.spotlightstores.com/sewing-fabrics/quilting/wadding-batting
grasshoppa Posted August 25, 2020 Author Posted August 25, 2020 Thanks very much for your help will get some jersey fabric for the viewing side and the backing stuff you recommended
Guest Peter the Greek Posted August 25, 2020 Posted August 25, 2020 4 hours ago, grasshoppa said: i want to make drapes I've misunderstood. What's the purpose of the drapes?
grasshoppa Posted August 26, 2020 Author Posted August 26, 2020 Ok! i have a room which is 12m long! i want to make it smaller I think maybe because there is tiles on floor, which is bad for acoustics. If I mAke the room smaller with drapes then I only have to have a rug only the size of a smaller room. Or don’t you think I need one.
Guest Peter the Greek Posted August 26, 2020 Posted August 26, 2020 Drapes of any fabric will do diddly. Use whatever curtain fabric you like. The only way to do something material in that space is to line the ceiling with panels or similar. Or carpet the floor
grasshoppa Posted August 26, 2020 Author Posted August 26, 2020 I would love to carpet the whole down here but it floods. So I can only use a rug big enough for the movie area. 4m x 5.5. Area. So you think don’t worry about the curtain and put ceiling panels. I can make them ? Won’t it be a problem if it’s all opened up. What I mean there will still be tiled exposed. Maybe panels over most of ceiling. Scattered ??
Guest Peter the Greek Posted August 26, 2020 Posted August 26, 2020 51 minutes ago, grasshoppa said: Maybe panels over most of ceiling. Scattered ?? Rule of thumb is 30% of floor, wall, ceiling. Do't take that as gospel. The best way to do a ceiling is fabric track - so attach the [whatever you're using - say ultratel] then have a fabric track that covers the whole thing......its going to get expensive..... You could get some polymax or whatever its called, attach it to the ceiling and see. 50mm of the 48kg stuff. You can get these things called "insulation pins". They might hold it, at least as a temp whilst your trying it. They're adhesive too, so wouldn't so too much damage - failing that, bang a screw in and patch it if it doesn't work
Guest Peter the Greek Posted August 26, 2020 Posted August 26, 2020 (edited) 1 hour ago, grasshoppa said: Sorry peter how do you mean track? google fabric tracks. Also look on AVS Here is a local example https://www.acoustica.com.au/product/descor/ Edited August 26, 2020 by Peter the Greek
