Further information:
Zero Zone Linear power supply. From memory I spent approx $350 shipped on it originally. It has two outputs, one at 5v and one at 9v. I bought this in 2018 from the following ebay user (here is a similar newer iteration of it on zhufan's account https://www.ebay.com/itm/S120-60W-60W-R-Core-Ultra-Low-Noise-Linear-Power-supply-2-way-DC-5V-24V-LPS/133606272916?hash=item1f1b8def94:g:NLAAAOSw-wZf142N).
It served me well for a quite some time, and the performance gains in my system encouraged me to experiment with using even higher quality power in my system (using Paul Hynes & Uptone supplies now). I no longer need it, but I'm also hesitant to use it/experiment as I believe it needs some service! My aim is to pass it onto someone who can make use of it.
IMPORTANT:  When I last used this power supply on a USbridge I had lying around I ended up frying the USbridge! I was so frazzled at the time I can't be certain I didn't connect the wrong output... but assuming I didn't, I think the voltage regulation on one of the outputs may have failed. Given this, I'm offering this power supply with no guarantee it's working as correctly. I just want to make it available to someone who might have some DIY chops, and is comfortable inspecting it so it doesn't end up in landfill. The sale comes with no guarantee of a working unit, and I've priced it 'for parts'.
I will list some GX-16 power cables from Ghent audio that I paired with it in a separate listing.
Pick up available in Richmond, VIC
Photos:
IMG_5544.thumb.jpg.3b137bb372613b353f6750a298b1c4d2.jpgIMG_5545.thumb.jpg.88a32a43473a4e595fe51ac9817c6b71.jpg
Can I also have your Custom DC22 1 Oyaide DC-2. 1G to Aviation GX16- 2 DC Cable Length: 1. 3m, Pin1(+) together with the zero zone p/s.
