fourier Posted May 9, 2002 Posted May 9, 2002 Can you recommend me a receiver for Mirage AVS system around the $500-$600 price range? I have a Yamaha rx-v430, which sounds a little bright to me when pumping digital PCM from my DVD player. ( in stereo mode using their the receiver's digital to analog converter). Using the analog output from my DVD player , playing CD, sounds better. How about a suitable cable? thanks
Guest queks Posted May 9, 2002 Posted May 9, 2002 i used to pair it up with yammy 800. Sound OK to me.
fourier Posted May 9, 2002 Author Posted May 9, 2002 i used to pair it up with yammy 800. Sound OK to me. thanks for the response. Do you know where I can audition a Yammy and may I know the price range of a Yammy? thanks.
limos Posted May 9, 2002 Posted May 9, 2002 Go KEC and look for Clarence or Chun for audition. Clarence talks alot whereas Chun is not. They are both brothers and nice to deal with. I got it for $728 incl GST last year Dec at KEC.
Guest queks Posted May 9, 2002 Posted May 9, 2002 You stay Woodlands right. If you want to audit with yammy 800, can bring 2 spk to my house. i stay Woodlands too ;D Anyway, if you're going for music, you can try Onkyo. Quite good in music.
fourier Posted May 9, 2002 Author Posted May 9, 2002 You stay Woodlands right. If you want to audit with yammy 800, can bring 2 spk to my house. i stay Woodlands too ;D Anyway, if you're going for music, you can try Onkyo. Quite good in music. Gee.. thanks for the offer! The receiver is a little over my budget. *sigh*. If really cannot find one <$600, then will consider the Yammy. (any specs?. I can't find the website). I heard that the Onkyo receivers are even brighter. Never heard one before tho'.
Guest queks Posted May 9, 2002 Posted May 9, 2002 go kec and tell them your budget. Listen to Onkyo. maybe you will like it
fourier Posted May 11, 2002 Author Posted May 11, 2002 Got the Marantz SR5200. KEC got no stock until estimated end of month so have to source it elsewhere. Worst, can't audition. So have take the gamble. As a token of appreciation to this forum, I'll post a basic comparison as a new thread. Thanks to all who gave suggestions. I'll be gone now to njoy the music.
