  • Replies 30
  • Created
  • Last Reply
Top Posters In This Topic
Guest saiful
Currently own a mission cinema 7 set and a Yamaha Amp. Would like to add the .1 to the system. Can anyone recommend a suitable subwoofer?
Would be using the systems for music and movie.
Budget about $400. issit sufficient? ???
If u can stretch your budget $95 more, go for the Yamaha YST-320 (which I used to own), as some here have recommended.
Im currently using a REL Strata III. Comparing the 2 subs HT-wise, the Yammy can actually hold its own quite well against the the REL (which costs 3 times more).
Of course, music performance is what separates the 2 subs (all subs for that matter).
The Yammy simply cannot keep up with fast rock/techno beats. But then again no <$500 sub can.
ermm.. but again if u dun mind there is port noise from the sub... when playing @ around 50hz & below.. quite irritating.. unless if u move it away from u in a corner....
i disagree on no <$500 sub can keep up.... juz because yammy sw320 is 10" it has higher inertia doesn't mean tat no other sub can...
i recommend MIRAGE FRX-8.. its fast... TIGHT! peaks @ 400watts... & its about $450 cheap & good.. the price might be lower coz the new mirage LF-100 subs replaces it...
Hi Guys, I just visited the Adelphi last weekend my first time...really... and I was so amazed of the HT displays that I saw, I think my JBL/HK is no comparison, I know they lag behind those seems to be sophisticated HT equipments.... :o but I just want to know your thoughts about "Wharfedale" (is my spelling right?) subs? any comments, the cost is S$380. ???
OH! yeah! heheh... its one of the budget subs around the 10" floorfiring one... well juz make sure u dun overload or demand to much from it... response wise is very average
may i know what do u use ur speakers for SHAQ? music? HT?
I use them for my own pleasure, I love music alot and watching my dvd's especially those war movies, that's why I want a little more boom boom sounds. Thanks for your advice. ;)
