Guest duckling
I suppose those stock cable will do just fine. No need to spend so much on cables from VCD to TV, you wouldn't see any significant improvement.
Consider an aftermarket video cable only if you are using a DVD player. VCD's have lower picture resolution and will not benefit from better cables.
Hi Guys,
I need a video cable to connect my VCD player to my TV, any recommendation? Budget is $50. Thanks.
Usually, the VCD Player will come with a standard RCA cable (RCA yellow head) for video connection. Since its VCD Player, it will make no difference between a $1 cable or a $100 cable.
