chucks Posted July 24, 2002 Posted July 24, 2002 hi, spend the whole day trying to find out whats wrong but to no avail. someone help. i connect my shinco to yammy with a digital coaxial. but when i play a dolby digital or dts movie, it cannot detect the signal. no sound came out and no dts logo is lighted up on the amp, meaning no signal rite? analogue workd fine but digital cannot. i change the coaxial to an optical but same thing leh. also, is there a way to resort all defaults. troublesome to do it one by one. help!!!
Ender1624705735 Posted July 24, 2002 Posted July 24, 2002 Probably your Shinco is not set up probably. For most player to get DD or DTS, make sure that the digital out from the player's setup menu is NOT set to PCM. It has to be something else, like for my nintaus player, it's set to RAW.
Guest queks Posted July 24, 2002 Posted July 24, 2002 If you're using Shinco 8700, you need to go to setup to enable digital signal out.
chucks Posted July 24, 2002 Author Posted July 24, 2002 oh...i see. kinda blur of me to miss it. thanks all.
