For sale is my highly regarded Plinius SA 250 MK2 in silver. This is an original MK II unit, it operates in fully balanced Class A . l would rate its condition as a very conservative 8, l cannot find any cosmetic blemishes on the amp at all (see pics below)
l purchased the amp off the original owner in New Zealand Feb 2005. Before shipping it to Australia l sent it to Plinius in Palmerston North where the amp was heat soaked, bias checked and went through all the QC checks a new unit would prior to shipping. It was given a clean bill of health, l was adivised the amp had seen little work and was in as new condition. Receipts for the amp service are included with the sale.
Rated at 250 Watts/ch into 8 ohms, 500 watts/ch into 4 ohms and bridgeable to 1000w monoblock operation. Switchable from class AB to full class A via the front panel. Comes with the original massive double box, manual, warranty card and invoice.
This amp drove my now sold Equinox Jupiter's with their sub 2ohm load with ease and sounds wonderful. Musically nuetral, it has a touch of warmth/tube like liquidity and posses none of the harshness and brightness normally associated with SS amplifiers. Retail on these l believe was originally around $14k, the current model retails for closer to $18k. The SA-250 is a real reference solid state amp
l am asking $3900.00 ono for the amp, this is a bargain when compared to other recent sales which see this amp go for upto $5k+. l will leave the amp here for a couple of weeks and then will give eBay a try. Any questions don't hesitate to drop me a PM.
Cheers Mondie
_______________________________-
Here's some further info from the Plinius website:
PLINIUS technology includes fully balanced, class A operation for all products; this reduces many kinds and sources of distortion. The balanced circuitry inherently cancels out even order distortions, and the class A operation eliminates small signal nonlinearities and crossover distortions. A switch allows the user to select class AB operation; this produces less heat for noncritical listening (dance parties), and allows you to hear for yourself and appreciate the sonic benefits of class A operation, contrasted with the class AB operation mode that many other power amps (both solid state and push pull tube) employ. It also provides a convenient way of leaving the power amp on, and warmed up for optimal fidelity, at all times, but with reduced power consumption compared to the class A mode.
http://www.pliniusaudio.com/reviews/review09.asp
Specifications
250 watts RMS/channel into 8 ohms both channels driven, 500 watts RMS/channel into 4 ohms
Bridged Output: 1000W RMS (mono)
Dynamic Headroom: 1db or greater at 8ohms with music
Freq Response: 20hz-20khz +/- 0.1dB at 0hz
Distortion: Typically 0.1% THD at rated ouput
Saturation: 265 watts/channel or greater into 8 ohms
Voltage Swing: 130 Volts P-P
Current Output: 70 amps short duration continuous per channel (Fuse protected)
Rise Time: Typically 2 microseconds
Phase Response: +0 at 20Hz, -2 at 20kHz A-weighted
Input Sensitivity: 1.3 volts RMS for rated output at 1kHz
Input Impedance: 47000 ohms
Dimensions: 275mm H x 500mm W x 485mm D
Weight: 58kg (130lbs), Packed 65kgs.
  • Replies 31
  • Created
  • Last Reply
Top Posters In This Topic
Any ideas on what the replacement amp will be? apologies if this has been discussed elsewhere, it's been a while since I've been able to spend much time here. .... oh and good luck with the sale
Mmmm tempting, although I’m under a strict financial curfew these days, still trying to get my replacement speakers approved. :)
Good luck with the sale…that’s if I don’t weaken in the interim.
Spearmint, Nice amplifier if $$$$$ can stretch. I have compared this unit against Krells at the same price, and though I am no fan of current Krells this unit held its own and was very musical. Tony C
Spearmint, Nice amplifier if $$$$$ can stretch. I have compared this unit against Krells at the same price, and though I am no fan of current Krells this unit held its own and was very musical. Tony C[/b]
Gee thanks Tony…make my life miserable. :biggrin:
Had the big engagement bash last weekend, the credit card almost melted from the speed of the money passing through it…next up the wedding (date not set yet, still looking for venue) so must keep saving. :biggrin:
Had the big engagement bash last weekend, the credit card almost melted from the speed of the money passing through it…next up the wedding (date not set yet, still looking for venue) so must keep saving. :biggrin:[/b]
Hi Spearmint,
Do parents still pay for engagements/ weddings and things these days?. Your one generous Father,this is the twenty first century.
We payed all these things ourselves. Tony C
Just hold the reception in the box the Plinius comes with. :biggrin:
Kevin
Good luck with the sale Mondie,its beautiful.
Even if I had the spare $$ ,I'm sure my equipment rack would disintergrate underneath that weight.
Even if I had the spare $$ ,I'm sure my equipment rack would disintergrate underneath that weight.[/b]
Another positive Joz, You could remove the heating from the room as this baby runs hot.
Not an amplifier that would normally be stuffed in a cabinet.
Tony C
Tony C[/b]
I know,if I lived in Tassie I'd consider it. :wink:
Your right about the cabinet too,anyhow it'd be to hard lifting the unit above my head into my cabinet :)
Tony C[/b]
It's unfortunate but cannot be avoided. A powerful Class A Amp must by its nature be big and heavy, consume large amounts of electricity, and generate enough heat for a small house in a Qld winter.
I have resolved never again to buy a piece of audio gear that I cannot lift, and I could only have lifted that in my best days (sadly long behind me) by means of CONSIDERABLE exertion.
Now THAT'S an amp! Someone is going to get a bloody bargain here.
That observation is as true now as it was then. Combining as it does brute-force power, world-class finesse, superb build quality, and a genuine and engaging musicality, the Plinius SA-Reference is one hell of an amplifier. It does many things superbly, and nothing less than very, very well. To get what more sonic quality is available—and it's not very much—you'll have to spend multiples more. I recommend the SA-Reference with unabashed enthusiasm.[/b]
http://stereophile.com/solidpoweramps/506plinius/index1.html
good luck with your sale..I am showing this to my brother in law. He might be in the market for such a beasty.
Well, I haven't been posting much lately as I'm involved in some projects that are taking all my time and might mean that I have to access every spare dollar.
It's a damn shame, because I reckon this sounds like the nearest thing to a real bargain that I've seen for a long time. :)
Everything I've ever read about this beastie indicates that it's a truly world class amp that will drive just about any speaker without fuss or difficulty and sound marvellous while doing so. Knowing Mondie, I suspect it's likely to be closer to 10/10 in condition, too.
Best of luck for a quick sale to a very happy buyer, mate. I'll be very surprised if that's not an imminent outcome.
Tony
Thanks for all the posts guys, l have had quite a few nibbles from my AudioGon ad but not a serious bite as yet. l will let it run for another week or two and then stick it on fleabay.
Cheers Mondie
