strauss Posted December 2, 2009 Posted December 2, 2009 Hi bro, I would like to get Belden sub woofer rca cable to contect to my active sub.Length will be 5M.Hope can get some advise whether Belden 1694A or 89259 is better. Thank you
armoury Posted December 2, 2009 Posted December 2, 2009 Id'd say just ask Robert for his advice. But gut tells me either would be fine, so you might as well get the cheaper (which I think is the 1694?) Subwoofer cable is not as 'fussy' as other analog interconnects.
EGG_Shell Posted December 2, 2009 Posted December 2, 2009 1694 will do. the more expensive ones are just have better fire rating but same performance. fyi 5m should be around 29bucks.
strauss Posted December 2, 2009 Author Posted December 2, 2009 Hi bros, Thanks for the good advise.So Belden 89259 is more ex than 1694,right?
Guest jonlee Posted December 2, 2009 Posted December 2, 2009 1694 will do. the more expensive ones are just have better fire rating but same performance. fyi 5m should be around 29bucks. You are referring to 1695. 89259 is a totally different cable. For sub, 1694 will do.
