Guest CASH Posted December 26, 2014 Posted December 26, 2014 sorry bro... i can't answer that question, as i only play with physical discs. i don't play with iso, hdd, nas, samba.... never went down that path.... sorry...
j2kbdr Posted December 26, 2014 Posted December 26, 2014 160 CFW worked very well thanks. 3TB ISO is working. ;D Also no cinavia ;D
pepefsd Posted December 28, 2014 Posted December 28, 2014 Hi! Please could you tell me what firmwares have MPS (movie poster system) inside? I have hd sir registered ( I don't know which version really) but it doesn't show the menu in the Pio. I can see it in my computer though My son is asking me for the covers everyday ::) I had a western digital before the Pio and showed us the covers perfectly.. Thank you very very much fot your help Regards!
Guest CASH Posted December 28, 2014 Posted December 28, 2014 Sorry. I dont use mps.. only physical discs.
pepefsd Posted December 28, 2014 Posted December 28, 2014 Hi Cash! Thank you very much for your quick answer.. This is a screenshot of my HD SIR firmware Would you be so kind to tell me which version do I have? I want to know it in case I can update it to a custom firmware with MPS.. I don´t mind NFS or network share as I watch films through Usb hdd. Thank you very much Cash for your help! :) Regards!
pepefsd Posted January 7, 2015 Posted January 7, 2015 Hi! Please anyone could tell me what version of hd sir do I have? I need to know so I can update it to a version with MPS.. Many thanks in advance!! :) Kind regards..
pepefsd Posted January 9, 2015 Posted January 9, 2015 Hi! I´m from Spain. I can´t speak or read in chinese.. That´s why I need your help.. :-[ Kind regards..
Guest CASH Posted January 9, 2015 Posted January 9, 2015 sorry bro, i am indian... and i also can't read chinese... i seriously, wish i could help u out... but i can't... :'(
pepefsd Posted January 9, 2015 Posted January 9, 2015 On 09/01/2015 at 3:50 PM, CASH said: sorry bro, i am indian... and i also can't read chinese... i seriously, wish i could help u out... but i can't... :'( Hi Cash.. thank you very very much... I´ve wrote a private message to Desray because I read in the thread that he can read chinese but he doesn´t answered me yet.. He´s my last chance.. :) As I have firmware registered.. do you think I could update it with another version of HD sir without problems? I´ve found some firms but I don´t know which one have MPS inside. Thank you very much again for your kind help Kind regards! EDIT: Can I update it with this firm of AceofSnakes without activate it? http://forum.ixbt.com/topic.cgi?id=60:3656-4
Desperado Posted January 10, 2015 Posted January 10, 2015 Let me give it a shot, as my Chinese is also limited. "This is a free distributed firmware, there is activation required. After firmware upgrade, can use all its jailbroken features, including "HDSir 2014 Spring" firmware. It can be revert back and forth with the original firmware. There is no further upgrade, modifications or customer support service for free this free firmware." Hope this helps
pepefsd Posted January 10, 2015 Posted January 10, 2015 On 10/01/2015 at 3:05 AM, Desperado said: Let me give it a shot, as my Chinese is also limited. "This is a free distributed firmware, there is activation required. After firmware upgrade, can use all its jailbroken features, including "HDSir 2014 Spring" firmware. It can be revert back and forth with the original firmware. There is no further upgrade, modifications or customer support service for free this free firmware." Hope this helps Hi Desperado! I appreciate very very much your help.. :) I'm going to try to update it with the russian firm with MPS since I don't know if there's a chinese HD Sir with MPS too.. Thank you very much again.. You've been very kind.. :D Regards..
urindian Posted February 6, 2015 Posted February 6, 2015 I flashed my BDP 450 with Cash Diamond ,I am still unable to play copied bluray discs ,,all the copied Pirated discs shows "UNKNOWN DISC" ;(
Guest CASH Posted February 6, 2015 Posted February 6, 2015 I am overseas now. Back tomoro. will reply then.. unknown disc can also mean the laser head has started to work up.. (Bad)...
Guest CASH Posted February 7, 2015 Posted February 7, 2015 to change region, press "8520" then choose your region.
Guest CASH Posted February 7, 2015 Posted February 7, 2015 On 06/02/2015 at 3:28 PM, urindian said: I flashed my BDP 450 with Cash Diamond ,I am still unable to play copied bluray discs ,,all the copied Pirated discs shows "UNKNOWN DISC" ;( have u tried to flash back to ver4.04? do activate it after flashing. try n see if the player can sense the disc instead of showing "unknown disc"
urindian Posted February 11, 2015 Posted February 11, 2015 how to activate it after flasing 4.04 ? Activator right ? is there a way to change bluray zone Tried the below ..still no luck..it is a new player Turn power ON. Press HOME key. Select Initial setup. Using remote, enter 3344. In new sub menu select region A (USA/Japan) B (UK/Europe/Australia) C (Russia/China/India) Press Return key. Player is now ready.
stigdu Posted March 26, 2015 Posted March 26, 2015 Hi all, I'm in the UK and bought a BDP-450 last week. Using the very helpful guides on here, I downloaded custom firmwares from a link provided by one of the chaps in the other discussion, and went from 2.09 -> 2.05 -> 4.0.4 which I am currently using. I only really wanted to have a multiregion blu-ray and DVD player as I don't do any of this network sharing stuff. My question is, would I see any benefits in trying to flash upgrade to 5.10? I think most of the improvements I've read about seem to be concerned with files on external storage devices, network shares and so on. The only improvements I *think* there might be is that : a) physical discs might load a bit faster b) some of the newer 'problem' discs (like Brave 3D) now work without problems I'm also a bit worried about 'bricking' my player, now that it's running 4.0.4 and seems to be ok at the moment! If I *did* upgrade to 5.10, I assume it's a matter of flashing the 'transition to 5.X' firmware first, and then the relevant '5.10 JAN 2014' firmware afterwards. Would I need to do any of that MAC code, serial number and PioX stuff on my PC again in order to get the codes? Sorry for all the questions, guys!!! Thanks :)
Guest CASH Posted March 26, 2015 Posted March 26, 2015 If u flash to ver 5... u got to use a different activator... Its not free.. I would jus stay at ver 4.. I dont need the external extra stuff. Only needed the multi region for bluray.
stigdu Posted March 27, 2015 Posted March 27, 2015 Just a note to say - I found out last night that it's a good idea to change the region on your player BEFORE you put the disc in. I put a Region A blu-ray disc in my player, and the thing froze on me! I had to reboot and quickly get the disc out so I could change region first, then play the disc. Cheers
alfie3 Posted March 29, 2015 Posted March 29, 2015 On 26/03/2015 at 12:11 PM, CASH said: If u flash to ver 5... u got to use a different activator... Its not free.. I would jus stay at ver 4.. I dont need the external extra stuff. Only needed the multi region for bluray. The Russians have 'free' versions of 5.10, see P5 of this forum. The advantages of some versions of 5.10 are speedier loading, plays all BD isos so far & plays some DVD isos (with a disc in the tray). It is not so good with MKVs - some will not fast forward or rewind. As stated in my previous posts, avoid the 'activation free' HDSir CFW for the BDP-450 as it has Cinavia.
Guest CASH Posted March 29, 2015 Posted March 29, 2015 maybe u can post the direct link here? it would be helpful.
alfie3 Posted March 29, 2015 Posted March 29, 2015 On 29/03/2015 at 8:36 PM, CASH said: maybe u can post the direct link here? it would be helpful. The link to the Russian CFW is here: http://forum.ixbt.com/topic.cgi?id=60:3656-4 A green tick means that free activation can be obtained using the Firmware activation link here: http://forum.ixbt.com/post.cgi?id=annc:60:3656 As explained previously you need to register with the forum & send a PM.
Guest CASH Posted March 30, 2015 Posted March 30, 2015 i have tried many times to register...but cant.. used chrome with translation.. press the button to register but nothing happens.. maybe u can help me? i have a LX-55 which i want to register the ver 5 firmware.. its stuck on unregistered ver 5 russion firmware.. jus need it to be registered.. tried to downgrade the firmware to ver 4 but it refuses to recognise the firmware.. so its still stuck....
alfie3 Posted March 30, 2015 Posted March 30, 2015 On 30/03/2015 at 12:16 AM, CASH said: i have tried many times to register...but cant.. used chrome with translation.. press the button to register but nothing happens.. maybe u can help me? i have a LX-55 which i want to register the ver 5 firmware.. its stuck on unregistered ver 5 russion firmware.. jus need it to be registered.. tried to downgrade the firmware to ver 4 but it refuses to recognise the firmware.. so its still stuck.... I had the same problem registering - you have to register whilst in the original language. Make a note of where the boxes are in English mode then go back to Russian to register. Have you tried installing the transition to 5.X CFW before downgrading to V4? I seem to remember it worked for me with the BDP-450.
