Sunny130y Posted December 20, 2015 Posted December 20, 2015 Just want to share above which I bought from Taobao #淘口令#长按复制这条信息,打开手机淘宝即可看到【独家新品留声机LP黑胶唱片机唱碟专用超声波清洗机家用小型清洁器】http://b.mashort.cn/h.Tha8d?sm=1bf76e Sort of Diy, it came with all parts need. Just need to install the motor to the tub. For instructions and learning can refer to http://www.tnt-audio.com/clinica/diy_ultrasonic_cleaner_e.html I use only RO water heated up to 50-55 deg celcius. https://vimeo.com/149537712 Sent from my iPhone using Tapatalk
jng2 Posted December 20, 2015 Posted December 20, 2015 Oh no don't use the clip to clip the lp directly you will damage the groove
blue_starfish Posted December 20, 2015 Posted December 20, 2015 Dry by inserting a string through the spindle holes, and then clipping the string on both sides to a bamboo pole. This way, the surface will not be scratched and the LP still able to air dry vertically.
Epicure2 Posted December 20, 2015 Posted December 20, 2015 The plastic pegs will cause damage to the records. Use these rack to dry your records after cleaning.
jeromelang Posted December 20, 2015 Posted December 20, 2015 Just want to share above which I bought from Taobao #淘口令#长按复制这条信息,打开手机淘宝即可看到【独家新品留声机LP黑胶唱片机唱碟专用超声波清洗机家用小型清洁器】http://b.mashort.cn/h.Tha8d?sm=1bf76e Sort of Diy, it came with all parts need. Just need to install the motor to the tub. For instructions and learning can refer to http://www.tnt-audio.com/clinica/diy_ultrasonic_cleaner_e.html I use only RO water heated up to 50-55 deg celcius. https://vimeo.com/149537712 Sent from my iPhone using Tapatalk This is the most stupid thing I've ever seen...!!!?!?? :P
Sunny130y Posted December 20, 2015 Author Posted December 20, 2015 This is the most stupid thing I've ever seen...!!!?!?? :P FUCK OFF[emoji867]
malsound Posted December 20, 2015 Posted December 20, 2015 Who, Hold your horses guys, we are all learning here, It is Ok to make mistake Lah. Christmas and New Year is coming. Enjoy your Vinyl 8)
naimster Posted December 20, 2015 Posted December 20, 2015 OMG... I see Diana Krall LPs hanging there. Please stop using the clips. It really can damage the LPs. Also the link to the taobao website doesn't seemed to be working.
Sunny130y Posted December 20, 2015 Author Posted December 20, 2015 Tested no damage done[emoji28]. Perhaps the vinyl is not as soft as we think. Thanks to epicure and bluestarfish for suggestions. Will try these gentler drying methods. Can attest the machine works like charm. Sent from my iPad using Tapatalk
Sunny130y Posted December 20, 2015 Author Posted December 20, 2015 OMG... I see Diana Krall LPs hanging there. Please stop using the clips. It really can damage the LPs. Also the link to the taobao website doesn't seemed to be working. Suggest search LP黑胶唱片唱碟清洁器 Sent from my iPad using Tapatalk
