Dear Friends,
The full ranges of JELCO TK-850 series Tonearm has arrived ! Includes the latest range of 10" TK-850M , and both 9" TK-850S and 12" TK-850L.
F e a t u r e s :
- Bearing for vertical direction equipped super steel metal KNIFE EDGE system.
- This Knife Edge material is specially made of super steel, and have very stable and smooth operation.
- This Knife Edge is precision hand made, and result is to have very low friction.
- Designed Hi-mass type system, and deferent kind metal material used for anti vibration, those are very low gravity, and low gravity sound created from this.
- Simple mechanism create good reproduction sound.
- The tonearm geometry allows for a Baerwald alignments which is IEC recommendations.
- This universal type counterweight can be used from 17 to 35 grs cartridge weight including head shell.
- TK-850S is fitted with a standard head shell and can easily be changed with other standard head shell (cartridge).
- This attached head shell can adjust the azimuth angle of the cartridge.
Price: TK-850S 9" - S$1500
        TK-850M 10" - S$1600
        TK-850L 12" - S$2100
Audio Basic
1 Coleman Street
#02-12 The Adelphi.
Tel : 6338 3245
