Further information:
Cyrus Stack for sale - CYRUS: 82 DAC QX, CYRUS: PSX-R2, CYRUS: PSX-R, CYRUS: STREAM X 2 SIGNATURE and CYRUS: CD7. No Box, comes with one remote and power cords. Manuals can be downloaded online.
All the unit has been serviced and checked, the streamer has been updated by the distributor.
All you need is a pair of speakers and you are ready to go! The PSX-Rs are used for the CD7 CD Player and the 82 DAC integrated amplifier which makes a big improvement.
- CYRUS 82 DAC QX – INTEGRATED STEREO AMPLIFIER | CYRUS
The Cyrus 82 DAC QX is an excellent performing integrated amplifier. Designed to excel, this element is a perfect acquaintance for the CD t or CD Xt Signature.
Scalable designed, the Cyrus 82 DAC QX integrated amplifier has a DAC card to convert digital sources to analogue without any mistakes or lost details. It delivers an impressive 70 Watts per channel with multi-zoning capacities. It incorporates six analogue inputs, headphone, twin speaker output, factory upgradeable.
The multi-zoning capacities of the Cyrus 82 DAC QX integrated amplifier let you listen to diverse sources in different areas of your home. It can be connected to up to five digital sources ranging from computer to satellite box. The Cyrus 82 DAC QX integrated amplifier is compatible with the high resolution 24-bit music files. Its on-board upsampling 24-bit/192 kHz DAC provides excellent audiophile performance. This audiophile integrated amplifier ensures clarity and depth.
Inputs - 6 analogue, 2 electrical SPDIF, 2 optical SPDIF, 1 USB (computer slave input)
Sample rate compatibility - digital input: 24-bit/192 kHz; USB: 16-bit/48 kHz
Outputs - Zone 2, preamp out, headphone, bi-wire loudspeakers
Power Supply - 350VA transformer
Power output - 150W per channel into 4 ohms; 70W per channel into 8 ohms
Product Specifications
  • Dimensions (HxWxD) in mm:  73 x 215 x 360
  • Outputs: Zone 2, preamp out, headphone,
  • Power Output: 150W per channel into 4 ohms
  • Inputs: 6 analogue, 2 electrical SPDIF
  • Weight: 6.9 kg
  • Power supply: 350VA transformer
- CYRUS PSX-R2 – FULLY REGULATED POWER SUPPLY | CYRUS
PSX-R₂
PSX-R₂ provides an extremely smooth and stable DC feed allowing any partnered component to achieve its full potential. Perceive new levels of fine detail, the PSX-R₂ allows you to comprehend subtle emotional nuances that expose the performer’s emotion and passion.
Re-designing a Classic
The PSX-R₂ is based on a design that has been in the Cyrus family for over 30 years. The latest improvements bring power supply filtering from the Anniversary system, culminating in the new v2 edition.
Instant Upgradability
The PSX-R₂ provides an instant sonic improvement to any compatible product. The benefits of a separate, isolated and highly regulated power supply allow internal electronics to upgrade their sonic performance.
Intelligent Connectivity
No modifications are required when connecting a PSX-R₂ to partnering equipment. Both units intelligently adjust output and input parameters to suit. Simply power off both units, connect and power on; internal circuitry detects the connection and re-adjusts perfectly.
300VA Toroidal
A 300va toroidal transformer was chosen for its ability to deliver an enormous current, forming the front end of the PSX-R₂. The 30,000 microfarad slit foil reservoir capacitors ensure that very low ESR and wide bandwidth are presented to the linear mode regulator stage that follows.
Over View
These elements are always captured in the recording but unresolved until the system is able to discern a higher level of detail. A stable, strong and separated power supply can provide huge sound quality benefits for a hi-fi system.
- CYRUS STREAM X SIGNATURE – PREMIUM STREAMING ENGINE | CYRUS
STREAM X SIGNATURE
Stream X Signature is our highest performance streamer source component; it uses Cyrus’ state-of-the-art streaming engine and has been developed to provide the best sound resolution possible from a network audio library. It will fully exploit the highest quality 24-bit/192 kHz files.
Advanced Engine
Supporting all popular formats, Stream X Signature is able to stream audio from USB, NAS drives or even iPod devices in high resolution up to 24/192kHz
Signature Digital Output
By removing all analogue audio components the Stream X Signature is a pure digital transport. This gives the best performance when using a digital output into Cyrus’ high performance DAC’s.
Essential Connectivity
Wi-Fi or Ethernet, integration into your home network is effortless and reliable. Additional sources? No problem, there are 5 digital pass-through inputs, and high performance digital output.
Internet Radio
If you love radio you will love TuneIn radio. With over 100,000 channels available, both local and national, the choice for music is as endless.
Effortless Control
Once connected, download our free Cadence app from iOS App Store or Google Play Store for a complete and intuitive control system. All key system functions, along with playlist creation and storing favourite internet radio stations, are available when using Cadence.
Overview
Make the most of the latest high resolution music files, or upgrade the quality of your CD resolution music1. Our flagship music streamer allows you to browse and select from your entire music collection using our Cadence app for iOS and Android.
Stream from any UPnP or DLNA device, or use one of the streamer’s host of additional inputs to play music from your PC or mp3 player. With simple set up, seamless navigation and sensational sound quality, listening to music just got a whole lot more enjoyable!
For the ultimate hi-fi system, use the Stream X Signature with a DAC XP Signature and a pair of Mono X 300 Signature’s . Include a CD Xt Signature to add CD compatibility to your system.
PSX-R
This intelligent, highly regulated audiophile power supply can be connected to the vast majority of Cyrus products. By providing an extremely smooth and stable DC feed, the PSX-R helps the partnered component to achieve its the full potential. This is one of our most popular upgrades and is highly recommended.
The PSX-R provides new depth and detail to the sound output of most Cyrus products by separating the processes within the machine. Low noise high gain amplifiers connected in a propriety design filter out any unwanted noise and provide remarkable benefits in sound quality. These improvements in sound quality are sure to make any audiophile smile.
By powering part of the workings of a Cyrus unit, the PSX-R lessens the strain on its internal power supply. This separation of power makes the unit work more efficiently, and creates a stronger and more detailed sound.
A fully regulated 300W DC power supply, the PSX-R uses intelligent connectivity which automatically adjusts its output parameters to suit the partnering Cyrus component.
Connection to a partnering Cyrus unit is made through a high quality XLR cable. In all instances this audiophile power supply can be added into the system without any changes to the existing components.
TECHNICAL INFORMATION
Electrical Outputs –
±35.5 VDC for stereo power and integrated amplifiers
±18-30 VDC for mono-bloc power and other amplifiers
±21 VDC for low power applications
Power – 300VA toroidal transformer
Dimensions (H x W x D) – 73 x 215 x 360 mm
Weight – 7kg
CD7
The CD 7 was a new platform for Cyrus CD players and includes the latest transport developments with our highly regarded 24 bit DAC technology, now built onto the main PCB. To help you keep up to date with rapid advances in IC technology we have included an interface to add a new DAC card at a later date. The optional DAC card is called Q7 and can be fitted by your Cyrus retailer at any point in the future, where available.
The CD player may be further improved by adding the PSX-R power supply. CD 7 succeeds by incorporating a wealth of digital and analogue expertise.
Monolithic triple beam Laser Assembly – Consistency, reliability and ultimate accuracy
High quality glass Laser optics – Minimal reading error generation
24 Bit Integrated Filter DAC – State of the Art technical performance, exceptional low level resolution
High precision quartz reference anti jitter circuit – High accuracy re-clocking eliminates timing errors
Specially developed analogue output stage – Low noise 4 pole filter design provides a flat response across audio band.
Extensive use of Star-earthing – Minimises power supply effects on audio signal
PSXability – Enhancing performance by further isolation of Power supply
Phase-invert facility – For absolute phase correction
Track skip programming mode – Selected tracks may be removed from playback
Non-magnetic lightweight die-cast chassis – Interference-free low-resonance enclosure
ELECTRICAL
Transport – Integral Isolated Loader Mechanism with monolithic glass LASER assembly
Disc Compatibility – CD, CD-R (closed), CD-RW (closed)
Outputs – Dual Stereo audio and SPDIF
Power Supply – 7 fully regulated power supplies
External – Highly regulated PSX-R upgradeable
Display – Custom LCD with subtle green back lighting
Remote Control – Full function remote control facility
Communications – MC-BUS™ System BUS
SPECIFICATIONS
Audio output – 2.1V rms.
Frequency response – 20Hz-20kHz
THD – <0.002% (ref. 1kHz, 0dB)
S/n ratio – 120dBA
Dynamic Range – >100 dB (20 Hz to 20 kHz)
Channel separation – >110dB (1kHz), >100dB (20kHz)
Digital output – Electrical SPDIF
Clock Jitter – <100pS
Power Consumption – 15W (12W Standby)
Weight – 3.5 Kg
Dimensions – (H x W x D) 78 x 215 x 360 (mm)
Finish – Black
Photos:
PLEASE READ
  • You understand that a reasonable donation for selling fees is expected upon successful sale of your item
Edited by beetle-audio
How much for the integrated+streamer?
It is the QX or QXR?
Thanks.
Edited by s7e6e
I do not think there is a QR model, only standard version or QXR.
Prefer to sell as a complete system but will see how I go for now.
Thanks!
That’s a lot of good gear for the $.
That streamer is putting a sparkle in my eye.
On 28/07/2021 at 4:58 PM, s7e6e said:
I meant QX or QXR. Thanks.
It is a QX! Thanks for pointing it out, honest mistake. Corrected.
Cheers!
A lot of awesome gear at a great price to be had here!
Edited by s7e6e
