nothing1 Posted August 22, 2021 Posted August 22, 2021 so the other day i went to undo the speaker cables from the speakers binding posts when it just started to spin so i undid the screws and got access to tighten them what i saw has me scratching my head and need some advise before i make allegations. I bought these speakers new or i thought i did from a well known supplier, from the picture you will see that it appears as though the top binding posts (high frequencies) have been disconnected(don't worry about the bent bits i fixed them)and reconnected into the one (low frequency) binding posts, to me it appears as though these were not brand new and even worse have been butchered. Any opinions on this? Thanks
tripitaka Posted August 22, 2021 Posted August 22, 2021 Well I think you can safely remove the question marks from your post title Sorry to hear of your experience. 1
nothing1 Posted August 22, 2021 Author Posted August 22, 2021 (edited) It looks as though I will be contacting the supplier in question tomorrow and depending upon the response I will either be naming them or be providing an update. Edited August 22, 2021 by nothing1 2
nothing1 Posted August 24, 2021 Author Posted August 24, 2021 (edited) spoke to supplier yesterday they have apologized for the speakers and have sent picture to Wharfedale QC they will get back to me once they hear back. I will post updates as i receive them. Edited August 27, 2021 by nothing1 1 1
nothing1 Posted September 1, 2021 Author Posted September 1, 2021 (edited) Major update there is nothing wrong with the crossover the upper binding posts are connected to the back of the board with a copper trace , also if i only connect the HF speaker cables sound comes from the the 2 HF speakers just as it should. Funny thing is wharfedale where going to fix them because even they did not know. anyway all is well that ends well Edited September 1, 2021 by nothing1
