Hi All
I am running a Cyrus One at present and was wondering whether hooking it up to a Cyrus power amplifierwould improve sound quality? How does it work? Connections wise I understand that it's via pre out...But are the sources connected via the amp or the power amp? And is there a possibility to borrow a power amp to test out?
It depends on what will match your speakers and whether they need the extra power. Often when this kind of thing is done you can get a stronger or more powerful sound but not always a more detailed or coherent sound so depends on what you like or can exactually appreciate.
Try googling for how to connect integrated amplifiers to power amps.
Edited by Al.M
  • Thanks 1
  • 2 months later...
With Cyrus  gear all  sources  is connect to your  from  what ever controls the volume in your case it would Cyrus one . With Cyrus power amp that  I have use in the pass ranging from bi amping to  mono blocks ( one power amp per speaker) you get more bass control  and more natural sounding easy on the ears.
