Further information: This LK140 from Linn is in very good secondhand condition. On sale in the shop for $1000 but for StereoNET members it is priced to sell at just $790.  The amp is direct-coupled and servo-controlled  and the toroidal transformer is fully shielded to prevent hum when the amplifier is stacked with other products. There are two input sockets to make it easy to daisy chain multi-amplifier systems, allowing you to boost the output power of your system, or take advantage or bi-amping and tri-amping.
Specifications:
Output power (230 Vac mains):95W per channel into 8ohms / 140W per channel into 4ohms
Input signal for maximum output: 870mV rms
Maximum output voltage: 23.5V rms (LK140
Gain: x27 (28.6dB)
Frequency response:(-3dB) 10Hz-70kHz
Output offset: <5mV
Signal sense threshold:>150µV rms
Standby power consumption: <5W
Maximum input power:570W
