Volunteer Kazz Posted October 2, 2021 Volunteer Posted October 2, 2021 Further information: Bought off a fellow SN member in Feb this year but have changed direction. I do not have original packaging but will be carefully packaged for shipping. The amp can beconfigured to output: 2 x 90WRMS 1 x 90WRMS and 2 x 45WRMS 4 x 45WRMS Specs: 2 CHANNEL MODE Power output into 8 ohms (20Hz~20KHz) ..............................................................90W With both channels driven Rated THD. .......................................................................................................0.03% 1KHz clipping power into 8 ohm ........................................................................100W Damping factor ....................................................................................................>100 Input sensitivity for 1W/90W into 8 ohm ................................................91mV/866mV Power output into 4 ohms (20Hz-20KHz) .......................................................... ..45W 4 CHANNEL MODE With all channels driven Rated THD. .......................................................................................................0.05% 1KHz clipping power into 4 ohm ..........................................................................50W Damping factor ....................................................................................................>100 Input sensitivity for 1W/45W into 4 ohms ............................................130mV/866mV Input impedance ................................................................................R=10K C=200pf Frequency response 20Hz~20KHz ................................................................+/-0.5dB "A" WTD. singal to noise ratio (ref. 1W/8 ohms) ...............................................100dB Dimensions (WxHxD) .......................................................................430x112x288mm Net weight ...........................................................................................................9.5kg Shipping weight ................................................................................................10.5kg Power consumption ............................................................................................360W Photos: you include any reference to pricing whatsoever in this section (excluding RRP), your ad will not be approved If you are advertising multiple items, you must post one bulk price only, or post seperate ads for each item If you don't include photographs of the actual item being sold, your ad will not be approved You understand that upon successful sale of your item it is expected you pay Seller's Fees. - if you have previously sold items and not made a contribution, your advertisement may not be approved. 1
