Further information:
Ayon Tube CD player- it is in excellent condition- just had new pair of OEM valves fitted- receipt available.
Pick up only as I  dont have any packaging for it.
From Ayon website:
Full-featured Tube Top Loader CD-Player
Class-A triode vacuum-tube output stage for single-ended & balanced operation
Signal Path
We believe that the simplest circuits work best together with the shortest signal path. That is why our pre-amplifiers to date have used single-ended pure class-A circuitry. The shorter the signal path is, the less possibility of sonic degradation from various sources, including the wire itself. Even on the circuit boards, the copper traces are kept to a very minimum length. The completely redesigned circuit board provides a more straightforward and direct approach to the signal paths.
Logical sequenced soft-start power up for extended tube life
Warm up function
0dB negative feedback  (of any kind )
Ultra short signal path
Simplest direct circuit path for purest musical sound and high reliability
Low output impedance for driving long runs interconnect to an amplifier, and any tube or solid state
power amp
No solid state devices in the analog tube output (signal path )
Minimal discrete wiring for optimum signal propagation
No followers or buffers in the signal path
No DC servo that degrades the signal
High quality parts throughout
Fully hand assembled to insure the highest level of craftsmanship
Separate analog output stage for left and right channel
Burr Brown D/A converter
Upsampling 24bit/192kHz
USB input 24/192kHz asynchronous
Digital output & input - S/PDIF (RCA)
Photos:
PLEASE READ
  • You understand that upon successful sale of your item it is expected you pay Seller's Fees.
    - if you have previously sold items and not made a contribution, your advertisement may not be approved.
