Hi All,
With short runs in a home, what is best way to go, split coax or toslink to multiple other devices ?
I have seen a powered 8 way toslink splitter, but there is coax splitters too.
Would prefer to use coax probably. Can you get away with something like the rca plug in splitters, they could be just put on back of each device.
Either would work, but toslink definitely needs a powered splitter as the illumination down the optical cable may not be adequate once shared. The problem with optical is the connections are flimsy and the boosters are pretty low quality and support only low sample rates, so it depends on the quality you're aiming for as to whether this is a viable option.
Coax is more robust but bear in mind at the high end quality level, multiple devices attached at the distant end will interact with each other, and interference, noise, reflections etc. may have an audible effect. This probably won't matter for the bulk of the time as coax has huge headroom to cope with the above.
  • 3 weeks later...
Hi All,
I sort of started to ask this elsewhere about coax/rca.
But started to think about ramifications of electrical signal and the load it may produce.
For spidif it may not be an issue ? can but multiple piggy back 1 rca to 2 rca. I do have switches already, but would like to get an output from a DAC and then branch this off to 2-8 other amplifiers so signal is just on.
I have seen people do it with toslink, maybe toslink is used because you only have to have a powered splitter, no concerns with resistance or what may happen down the line like with rca, coax may also be impacted like this ? I do not know enough about the specs to be sure.
Will xlr also have same issues if too many items daisy chained ?
What do you say ?
Is this not more complex and probably costly compared to say TOSLINK and a toslink amp/splitter.
I do not mind the signal always on to all devices.
Was going to use SPIDIF but suspect it may suffer from issues you can get with RCA.
I have one DAC that has a input and then either digital out choices, it just so happens to be the one connected ATM and is small.
I will have to read more about the device and software you mention, it is always good to learn about all options !
Hi Con, i just realised I have doubled up....
Maybe a mod can post your response here
and then delete this thread, or vice versa ?
You have described a multi room setup.
I would use RAAT, uPNP or squeeze using rpi4’s as endpoints to feed your dacs.
Either wired or wifi.
