Emerald Phono Amplifier by RJM Audio.
RJM Audio - The Emerald Phono Stage (phonoclone.com)
Features:
1) Switchable MM/MC phono stage.
2) Built around two stages of non-inverting op amp design.
3) Extremely accurate RIAA equalization.
4) *Input impedance: MC - 100ohm, MM - 47K
5) *Gain: MC - 59dB , MM - 39dB
6) Op Amp Socket used for op amp rolling (default: OP27)
6) Top quality part - Nichicon KZ, Wima caps, Solen Cap, 1% tolerance resistors
7) Separate power supply.
* Have provision to change in according to the cartridge used.
Edited by Marc
Contact information removed as per guidelines
