sootshe Posted May 23, 2022 Posted May 23, 2022 Further information: Audioquest Carbon Digital Audio Coax Cable, terminated in RCA both ends, .75m. One owner, in original factory packaging. As new, price includes postage. SOLID 5% SILVER CONDUCTORS IMPROVE ANALOG PERFORMANCE Solid conductors eliminate inter-strand distortion, one of the biggest sources of distortion in cables. CARBON-BASED 5-LAYER NOISE-DISSIPATION SYSTEM (NDS) It's easy to accomplish 100% shield coverage. Preventing captured Radio Frequency Interference (RFI) from modulating the equipment's ground reference requires AQ's Noise-Dissipation System (NDS). Traditional shield systems typically absorb and then drain noise/RF energy to component ground, modulating and distorting the critical "reference" ground plane, which in turn causes a distortion of the signal. NDS's alternating layers of metal and carbon-loaded synthetics "shield the shield," absorbing and reflecting most of this noise/RF energy before it reaches the layer attached to ground. FOIL + SILVER-PLATED BRAID SHIELD COLD-WELDED, HANGING-SILVER DIRECTLY OVER PURE PURPLE COPPER TERMINATIONS Cold-Welded, Hanging-Silver Directly Over Pure Purple Copper Terminations HARD-CELL FOAM INSULATION Hard-Cell Foam (HCF) Insulation ensures critical signal-pair geometry. Any solid material adjacent to a conductor is actually part of an imperfect circuit. Wire insulation and circuit board materials all absorb energy. Some of this energy is stored and then released as distortion. Hard-Cell Foam Insulation is similar to the Foamed-PE used in our more affordable Bridges & Falls cables, and is nitrogen-injected to create air pockets. Because nitrogen (like air) does not absorb energy and therefore does not release any energy from or into the conductor, distortion is reduced. In addition, the stiffness of the material allows the cable's conductors to maintain a stable relationship along the cable's full length, producing a stable impedance character and further minimizing distortion.
