MooneeBeach Posted June 11, 2022 Posted June 11, 2022 (edited) Hi - I recently purchased an LG BP60NB10 which had been modified to allow 4K ripping. Along the way, it's given me plenty of errors on what seemed like immaculate discs (only ever watched once, handled with care, etc.). Is there a drive which is better at reading these discs? I have around 15 discs that I really want to rip (some 4K some regular bluray). Any advice would be greatly appreciated. Thanks, Sean Edited June 11, 2022 by seaninbrisbane
Pegasus Posted June 11, 2022 Posted June 11, 2022 Use a PC with a bluray burner, or buy an external bluray burner. The external bluray burners are only about $50.
TP1 Posted June 11, 2022 Posted June 11, 2022 On 11/06/2022 at 8:23 AM, seaninbrisbane said: Hi - I recently purchased an LG BP60NB10 which had been modified to allow 4K ripping. Along the way, it's given me plenty of errors on what seemed like immaculate discs (only ever watched once, handled with care, etc.). Is there a drive which is better at reading these discs? I have around 15 discs that I really want to rip (some 4K some regular bluray). Any advice would be greatly appreciated. Thanks, Sean Expand Last time I had issues with bluray rips I switched to a Pioneer drive which solved many of the problems. That was a couple of years back but Pioneer has always made top notch optical drives. 1
Guest Posted June 11, 2022 Posted June 11, 2022 Check that the drive is correctly powered? Can it play a movie? It is using older PC technology and not all USB adaptors work. Am using this https://amzn.asia/d/2RbpUEd And I assume you are using MakeMKV? Have you tried getting help on that forum? There are combinations of drive models and firmware that the forum recommends but I am not across the details. At the end of the day, there is a risk that such drives will not work. I did a little bit of reading on the forum prior but was not totally confident that things will work. As such, I was prepared to write things off, but was lucky with an LG BH16NS55 with the correct firmware. Have no experience with your LG drive.
exitguy Posted June 12, 2022 Posted June 12, 2022 (edited) On 11/06/2022 at 1:35 PM, Snoopy8 said: but was lucky with an LG BH16NS55 with the correct firmware. Expand Same here, got that unit from MartyMcNuts (MakeMKV Forum) fully firmware updated and has been working without issues for a few years now. Edited June 13, 2022 by exitguy
MattyW Posted June 13, 2022 Posted June 13, 2022 I've found a similar problem when trying to rip Disney Blu-Ray to put on our NAS to use via Plex. Full of errors, and mostly stop at about 45% which makes me think they intentionally put errors on the disc to prevent easy ripping. If you do find a solution I'm keen to know about it. That said, picture quality via our Blu-Ray player is certainly better than Plex anyway but its still inconvenient.
MooneeBeach Posted June 13, 2022 Author Posted June 13, 2022 Thanks for the replies everyone. I might give the LG BH16NS55 a go, so if anyone would like to borrow my LG BP60NB10 and let me know how they get on with it, they are very welcome. 1
MattyW Posted June 13, 2022 Posted June 13, 2022 On 13/06/2022 at 1:19 AM, seaninbrisbane said: Thanks for the replies everyone. I might give the LG BH16NS55 a go, so if anyone would like to borrow my LG BP60NB10 and let me know how they get on with it, they are very welcome. Expand Does that rip Disney discs alright? If so I may need to source one.
MooneeBeach Posted June 13, 2022 Author Posted June 13, 2022 On 13/06/2022 at 1:24 AM, MattyW said: Does that rip Disney discs alright? If so I may need to source one. Expand Sorry, I don't have any Disney movies to try. Which drive are you using to rip? You're welcome to try mine.
Guest Posted June 13, 2022 Posted June 13, 2022 On 12/06/2022 at 12:03 PM, exitguy said: Same here, got that unit from MaryMcNuts (MakeMKV Forum) fully firmware updated and has been working without issues for a few years now. Expand I assume you mean MartyMcNuts! He is based in regional VIC. https://uhdenableddrives.com// On 13/06/2022 at 1:24 AM, MattyW said: Does that rip Disney discs alright? If so I may need to source one. Expand Sorry, have not done my only 4K Disney movie, Toy Story 4, but it is on loan at the moment. However, I have had zero issues with my 4K rips so far and do not anticipate issues. Suggest you contact MartyMcNuts to confirm this before buying.
Guest Posted June 13, 2022 Posted June 13, 2022 On 13/06/2022 at 12:54 AM, MattyW said: That said, picture quality via our Blu-Ray player is certainly better than Plex anyway but its still inconvenient. Expand Suggest getting a Zidoo, Dune or Zappiti HD player. I have used Zidoo and Dune. The video quality is excellent, just slightly below my bechmark Pana DP-UB9000. The user interface is good and Plex is not necessary, but I have read that some people have loaded Plex.
