Guest Nay9 Posted September 4, 2005 Posted September 4, 2005 Selling a valve Preamp based on the circuit modified from convergent SL-1. http://eshop.diyclub.biz/product_info.php?...&products_id=63 This Preamp is complete, it uses the stepped attenuator, gold plated RCA jacks, 4-way source Input selector, toroidal power transformer and the medium metal chassis (Black) from this site below. http://www.diyfidelity.com.au/index.php Some of the modifications I've made to this Preamp are as follows:- Replaced the standard SCR caps with Auricaps and the standard coupling caps have been replaced by Mundorf M-Caps, have changed out all the valves on the preamp section to Electro-Harmonix tubes, no ring tube rings and sound damping pad on the top plate. Reason for the selling is, I'm buying a SS Preamp of the same make to match the IRD Monobloc poweramps I have, and the volume steps are to far apart on the Valve Preamp for late night listening The sound is smooth without lose of fine detail. The unit is around a month old with around 120 to 150 hour use. Cost to build this unit with the mods was around the $930 mark. Selling for $300 firm. Throwing in some spare parts:- 1x stepped attenuator (Value 100k) 2x JJ ECC82 Tubes, 1x Ei 6DJ8 EG Tube, 1x Electro-Harmonix ECC82 Tube. Email me if Interested neptune@bigpond.net.au
Guest Nay9 Posted September 4, 2005 Posted September 4, 2005 Had posted this unit on a another forum also. The Preamp has been SOLD
Guest Nay9 Posted September 10, 2005 Posted September 10, 2005 The sale for the Preamp fell through, so it is still up for grabs if anyone is interested.
