Anybody know about this amplifier? is it good match of B&W 805S or 805D3
@Sect
No problems, it's solid state it will be fine. Only if it were tube the it "could" have trouble if the epdr (worst low impedance) of the B&W's is savage.
Just added
https://www.stereophile.com/images/317BW805fig01.jpg
The nominal impedance is 8 ohms; the solid trace in fig.1 reveals that the magnitude drops below 8 ohms between 100 and 750Hz and above 8kHz, with minima of 4.6 ohms at 180Hz and 22kHz. The electrical phase angle (fig.1, dotted trace) is occasionally extreme, with combinations of 6 ohms and –35° at 118Hz and 8.2kHz. Tube amplifiers will probably work best with this speaker when used from their 4 ohm output-transformer taps.
Cheers George
Edited by georgehifi
  • 2 years later...
